$$Costly Radiator blues
Old Dec 28, 2012 | 03:45 AM
forbiddenvette's Avatar
forbiddenvette
Default $$Costly Radiator blues
Z51 replacement $400 (deal) OEM $500+ and still high oil temps with a modded engine.
Cure
Setrab cooler
-10 Tstat
s/s hose -10 fittings
custom -10 oil cool adapt
fab bracket
$500
Base aftermarket radiator $165
Re-cal fan speed for 204' temp target $0
results- oil temps never over 203' ... coolant temps never over 217'
Your thoughts?
Old Dec 28, 2012 | 09:19 AM
timd38's Avatar
timd38
I did a Z07 radiator with a 2008 Z06 oil cooler. Oil temps about the same, but water temp stays around 200 on a 90 degree day.
Not sure what you mean by modded, but I have a 540+ at the wheels, 416" LS3.
Old Dec 30, 2012 | 12:19 AM
NSANEC6's Avatar
NSANEC6
Cure
Setrab cooler
-10 Tstat
fab bracket
$500
Your thoughts?
I would love to see some install pics. I am having cooling issues on my build as well. I am looking at doing an external Setrab cooler over the winter. I see constant 245/250 engine oil temps when its 80 plus degrees ambient temp outside.
Old Dec 31, 2012 | 02:07 AM
forbiddenvette
Yup, I'm putt'n down around 490whp with an LS2. OE Z51 rad ain't cutting it .
Old Dec 31, 2012 | 02:16 AM
forbiddenvette
Pix will post when I get back in town Wed 2nd
Old Jan 4, 2013 | 12:48 AM
forbiddenvette
Old Jan 4, 2013 | 12:52 AM
forbiddenvette
Old Jan 4, 2013 | 12:54 AM
forbiddenvette
Old Jan 5, 2013 | 04:10 PM
NSANEC6's Avatar
NSANEC6
Thanks. Unfortunately with the transmission cooler that I have I do not have any room where it looks like your oil cooler is installed, Looks like ggod work though.
To $$Costly Radiator blues
