reuse ls2 timing chain or not?
Old Dec 29, 2012 | 05:53 PM
titleist's Avatar
titleist
Default reuse ls2 timing chain or not?
when doing a cam swap what do you guys think about reusing the stock ls2 timing chain?
Old Dec 29, 2012 | 07:46 PM
timd38's Avatar
timd38
Low milage no, over 20K miles, yes.
That being said, I put a cam in at 10K and replaced the chain.
Just my opinion.
Old Dec 29, 2012 | 07:59 PM
RicK T's Avatar
RicK T
I have to ask why even consider reusing something that critical? Not like it's expensive or anything. FWIW, I would not reuse it.
Old Dec 29, 2012 | 08:01 PM
etaylor14's Avatar
etaylor14
It is foolish not to replace the chain any time you have the front cover off.
Old Dec 29, 2012 | 08:11 PM
titleist's Avatar
titleist
well, i actually have a brand new LS2 chain that i bought and never used.
i guess my question is.... it is new and a direct replacement from what i got. should i throw a hundo at a C5R chain? or just use the new LS2?
also i would like opinions on upgrading to a high volume oil pump
Old Dec 30, 2012 | 04:22 AM
taken19's Avatar
taken19
Track Junky
Since you going through all the effort, I would change the chain. It's relatively low cost extra and zero additional work. I'd also consider the C5R chain for added reliability.
Old Dec 30, 2012 | 04:54 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Yes, especially with regard to the C5R chain.
San
Old Dec 30, 2012 | 11:23 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
What damper are you using?
Old Dec 30, 2012 | 12:18 PM
titleist's Avatar
titleist
stock damper. why?
Old Dec 30, 2012 | 02:51 PM
glenB's Avatar
glenB
Originally Posted by titleist
stock damper. why?
Do a search on broken timing chains.
The C5R at least gives some security.
Old Dec 30, 2012 | 03:12 PM
taken19's Avatar
taken19
Track Junky
Absolutely!!! I lost my motor last March due to a broken timing chain with an ASP pulley (best guess with input from Jason Katech). And that was with a C5R timing chain. Run a search if one of my treads back in the March or April 2012 timeframe for details.
Old Jan 2, 2013 | 10:34 PM
Gering's Avatar
Gering
Tolero Apto Victum
If you ever have to replace a damper I would recommend ATI.
Old Jan 3, 2013 | 12:36 PM
Don 79 TA's Avatar
Don 79 TA
a plus to using the old one, again somewhat low mileage is its probably at it's stretched length now
but... sometimes for the piece of mind it's just worth replacing while you're in there
kindda like on some cars when you do timing belts, might as well do a water pump
To reuse ls2 timing chain or not?
