Battery tender
Old Dec 31, 2012 | 11:38 AM
Runflatred's Avatar
Runflatred
Default Battery tender
I have a 2013 Grand Sport and bought a battery tender. The instructions say to connect it to the battery terminals. My car has a remote positive away from the battery. This is where I would connect the leads if I want to jump start the car. Should I also use the remote for the tender or should I connect direct to the battery? Thanks in advance.
Old Dec 31, 2012 | 03:44 PM
kmthor00's Avatar
kmthor00
I wouldn't think it matters either way, I have always connected my tender directly to the battery
Old Dec 31, 2012 | 04:31 PM
RicK T's Avatar
RicK T
I just connect directly to the battery term's but others use the remote location. Not an issue either way.
Old Dec 31, 2012 | 04:43 PM
Z06pete's Avatar
Z06pete
I have a 2007 Z06 and I use the remote terminals under the hood. It works great.
Pete
Old Dec 31, 2012 | 04:45 PM
Homer3D's Avatar
Homer3D
I have my tender hooked up to the alternator. Works fine.
Old Dec 31, 2012 | 05:50 PM
ittlfly's Avatar
ittlfly
I used ring terminals to connect mine to the remote + terminal under the hood and the - to the engine block. From there I ran a 12' extention under the air bridge down to the left front of the spliter. That way I never have to raise the hood to connect or disconnect the tender.
Old Dec 31, 2012 | 06:01 PM
chimazo's Avatar
chimazo
If you generally front-in your garage, connect it under the hood, and if you typically back-in, connect to the battery. Under the hood is easier, actually, and you can close your hood with it connected if leaving it undriven for a while.
To Battery tender
