Planning on buying a 2009 C6 Coupe with manual and Z51 option. Mod are planned with Haltech LS3 CAI and Beehive shroud, lower temp thermostat, Kooks 1 3/4" long tube headers, catted X-pipe, Borla Touring axle back exhaust, lowered on stock bolts and a tune & dyno pull or two. Will be moving back to Henderson, NV. prior to buying the 09 C6.
Would a small aftermarket cam and new springs be worth it, since I'm not doing any mods to the intake system?
I put the GM 'Hot Cam' in my 2008 Coupe and was very happy with it. GM Performance Parts Catalog advertised 50 hp and 50 ft/# torque. It felt good to me!
Small is a relative term... how small are we talking?
Homer3D, yours is a little more intake lift & a little less exhaust lift than what I'm planning. Sure would like a little idle rattle though with this cam change. 50+ rwhp/50+ rwtq sounds great.
A 224-230 is worth about 35-45rwhp on a ls3 with proper tuning... It will have a slight idle depending on the lsa .. We have some nice custom grinds for ls3's, feel free to pm me for info...
On the LS3 it will make around 465 to 470 to the wheels. Something being worth it, is clearly individual. 50hp for 2500 bucks is about $50 per hp and within reason.
A 228/232 has made as much as 493rwhp (LG motorsports) as posted by Lou Jr on LS1tech. Its likely to average 475-480rwhp though.
Since a 228/232 drives nearly perfect and passed the sniffer for me in NY, I'd say its a better move with no downside that I can think of. I also had the XER273HR from comp cams which is a 224/230 114+1 and that passed the sniffer too.
C5FRCPewter, I think the gains are cam & springs. I went from 364 rwhp to 397 rwhp with Z06 intake & Filter, 160 t-stat, Kooks 1 7/8" headers, Kooks catted X-pipe, Borla Touring axle back exhaust, and a tune. If this cam/spring change is good for >50 rwhp, I'm in. But, there's always a but, a cam change is $2,000 with parts and labor(cam, pushrods, valve springs, gaskets, oil, coolant). Hey, ya only live once, right? Eh, need an oil change anyway.
Spin, you still in NY?
i moved out in 08 and did inspections (license still valid )
anyway.. thought the sniffer went away in NY and it's now plug in to scan the ODBII's
Look into the LPE GT-11 cam. It idles very tame and has a good amount of lift and duration. It doesn't even require a higher stall converter with an auto. My car made great power and pulls hard.
