Goodyear Gen 2s- Cold Weather experience
have moved from Virginia over to Germany/Munich in October.
My 2011 Grand Sport has received new GY Gen 2s before we moved.
Have run the car some 300 mls still in the US in warm to hot weather conditions.
The Gen 2s were a big improvement and I was extremely happy.
Now, after moving to Germany and under rather cold (but not extremly) conditions around 35 F, everything seems to be very different.
- I have to add, that after the container transport to Germany, the (one of Germanys best) Corvette Shop, which made the conversion to European reglementations, checked the car and found the steering gear (play) and all 4 stabilizer links worn. Transport damage. Steering gear and 4 links replaced, alignment was done.
Still, the tires work badly under colder weather conditions. I know those tire aren't made for winter conditions, but these seem to work extremely poor.
When parking the car, over moving it slowly with high steering angles, the tires are vibrating heavily. Knew this effect before, but way less strong and rather at temperatures around 15 F.
The slightest grooves in the road makes the front wheels go in all directions, big impact in steering.
Traverse grooves in front of a traffic light when accelerating with very little throttle gives wheel hop and the back snaps...
Has anyone made the same kind of experience with the new GY Gen 2s in the Grand Sport tire size (275 front, 325 rear)???
Take care
Mirko
We had Firestone runflats on our C5, and Michelin PS2 runflats now on the C6. Neither of them could get up our slightly inclined driveway with less than 1" of snow on the asphalt. The Firestones also turned to "stones" at low temps, driving on bare/dry pavement at -10'F was like driving on ice. The PS2's seem to do a bit better on temp but I haven't driven them below about 25'F.
OTOH, our Michelin A/S runflats easily handle 2" of snow and cold temps.
The tire shudder you are experiencing may just be normal, but increased due to the colder temps.
Setting up our car with a little toe-IN, front and rear, made it much more stable over bumps, undulations, and grooves.
Good luck, I think you may be screwed for winter driving most of the time. Hopefully, someone has better ideas.
the strange thing is I have driven C6 s incl. Z06 since 2008 in Virginia (Alexandria) as daily drivers incl. winter. No big problems apart snow. Tires have always been the GY Supercar runflats 1st generation. I was so enthusiastic about the Gen 2s in summer...
Take care
Mirko
Once you have check the aforementioned then we can discuss the wheel hop issue
When it gets cold (temps under freezing) we switch to winter tires. The summer do get really really slippery and the cars would be undrivable in true winter conditions with them.
I tried A/S's for one winter (Yoko's on the front and Avons on the back) and it was DANGEROUS in snowy conditions (anything more than a inch or two).
we now use Pirelli Winter tires (winter sport 210 on the C4 and Sottozeros on the C6) and the cars are completely drivable in snow storms and cold weather with them. However, it may be very very difficult to find winter tires in your sizes. For the rears (285/35-19) on the C6 we found one and only one winter tire and that is the Pirelli Sottozero.
I went to the Bridgestone runflats, and they hold very well in cooler temps, even into the high 30's.
Meaning, I have to try hard to make it spin in 2nd, and when it does, it makes a very loud bark.
If the roads are 60 and up, it just rockets and goes with the LS3 stock power.
Checked all suspension, took sway bar links off to verify front sway bar. Nothing found. Car runs like on eggs...
No cause found. Next step will be to start replacing one suspension part after the other.
Any ideas? Please help!
Mirko
Mirko
Also, your description of the front end "knocked up" sounds exactly like the tire scrub we all experience, especially in cold weather with (usually) sticky tires.
Spent a full day with the mechanic in the shop to figure it out...
Could a diff problem be a cause for the front wheel hop?
Mirko
The hopping is what happens when the grip sucks, it's a scrub radius thing... runflats do it worse because of the super stiff sidewalls.
Yeah, get a set of winter tires, at minimum some kind of all-season (there are some pretty good Ultra High Performance All Seasons) at least they have compounds meant to work when it's cold. Trust me it'll drive better not worse.
If your car now rides unlike it ever did in Alexandria, VA in the cold weather (note: Alexandria does have 35 degree weather; it is that right now), and causes this almost cobblestone-street ride (similar to Prince Street in downtown Alexandria) at full lock (turning to the end of the turning circle), and the tires are not the issue since you tried different tires, nor is the alignment, then all I can guess is it is the suspension parts installed, and/or the method of tightening them down. This shop has possibly done something wrong, or used a wrong part. It is possible that something else is worn or broken but they would (might) have seen that in their first and subsequent inspections.
I do know that "bluewasp" (Springfield, VA) has been in Germany in the past with his Corvette. You may want to ask him who/what shop he has used, if any.
To add to our pain I have seen GY bulletin(hopefully not fake) that DAMAGE can occur if driven in < 40 deg!!! Cracking on the tire. I have really limited my cold weather driving and may go back to GY Supercar like on the '08 Z06. Had the '08 for 4 years and no problems in cold----big loss of traction but I could manage that.
BTW I too love the G:2 in warm weather
I have still the same problem after two shops and 5 alignments. Also winter weather is a problem as you can rarely test drive the car.
German Corvette Expert thinks that the bolts have not been sufficiently tightened as both shops only used 12 inch long wrenches, not a torque wrench.
Will make the next try when dry conditions are back.
Would be very interested in the bulletin!
@AORoads - the oversea transport by ship was actually more than 4 weeks! They started in Baltimore, went down to Mexico, back up to New Orleans, Wilmington and only then across the Atlantic...
Take care
Mirko
