Diff Question
Old Jan 3, 2013 | 08:23 PM
timd38's Avatar
timd38
Default Diff Question
I have a Z06 diff heat exchanger with lines that I want to install in my 2006 Z51 M6.
RPM can machine the gears to work with the Z06 pump, but I need to use a Z06 rear cover to mount the pump to because Z06 has a two peice cover and mine has a one peice cover. Does anyone know if I get the Z06 cover if it will bolt up to a Z51 diff?
Thanks!
Old Jan 4, 2013 | 11:25 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Thanks!
Yes, you can use the Z06 diff rear cover/pump on base C6 diff as long as you machine the pinion gear. We have new and used rear cover/pump in stock.
__________________
Old Jan 4, 2013 | 07:02 PM
timd38's Avatar
timd38
Thank you very much! I had everything in the box, I just did not look hard enough.
Old Jan 4, 2013 | 07:05 PM
Supporting Vendor
LOL.
To Diff Question
