Clutch capabilities
Old Jan 8, 2013 | 05:22 AM
Nik_Bad's Avatar
Nik_Bad
Default Clutch capabilities
How much non racing power can my stock clutch take? I have an 08 z51 C6. It has about 25k miles now. It has never seen a strip or really hard starts. All the "racing" I have done has been rolling and involved 1 shift max. I am putting on an A&A kit when I get back in the spring. I have been debating putting in a ZR1 cam while it's in the shop. At the end of the summer I will do a new clutch. I am just wondering if 700 RWHP lightly driven is going to cause me any issues before I can upgrade the cluch and such. I tried searching the forum for an answer but I am using my iPad with VERY slow Internet so my search was fruitless. Thanks guys!
Nik
Old Jan 8, 2013 | 05:53 AM
timd38's Avatar
timd38
Clutches are like brakes, depends on how you drive.
Old Jan 8, 2013 | 10:44 PM
narfdanarf's Avatar
narfdanarf
No. From what I have seen, most will give up the ghost in the 5xx whp range....depends on how much torque really.
Old Jan 8, 2013 | 11:23 PM
Nik_Bad's Avatar
Nik_Bad
Not quite following you. Could you elaborate, please! Thanks!
Old Jan 10, 2013 | 08:43 PM
narfdanarf's Avatar
narfdanarf
Clutch holding capacity is based off torque, not hp or shifting or anything like that. Stock clutches get iffy at the torque equivalent to 500hp..700hp is too much by a long shot. If it lives long enough to tune the car at that level which I don't think it will, then you won't be able to drive at that level on the street even doing rollons, which cause more perceived torque than short bursts.
To Clutch capabilities
