Post up your drag set up
Old Jan 13, 2013 | 03:08 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Originally Posted by 03justin
if you dont mind me asking what kind of suspension are you running.i had qa1's but just bought the pfadt drag package.the car looks bad *** pulling the wheels.
100 percent bone stock EXCEPT front sway bar is removed. Stock shocks and all 22k miles on it.
Old Jan 14, 2013 | 11:08 AM
EVL JAKE's Avatar
EVL JAKE
St. Jude Donor '12-'13
Originally Posted by Le Mans C6
What kind of mods are you running to need a 15" rear tire?
Currently I don't need a 15 but either when I spray or go with boost I will. I run in a lot of grudge events so prep isn't always the best. More side wall is always better.
Old Jan 14, 2013 | 10:01 PM
huggerorange73's Avatar
huggerorange73
2026 Corvette of the Year Finalist - Modified
2025 C6 of the Year Winner - Modified
Why in the world do you need a 15" wheel/tire combo to run 12's.
Old Jan 15, 2013 | 12:14 AM
EVL JAKE's Avatar
EVL JAKE
To look cool?
Old Jan 15, 2013 | 11:19 AM
huggerorange73
To look cool?
You're such a poser.
Old Feb 4, 2013 | 08:30 AM
ajw2500hd's Avatar
ajw2500hd
sick
Old Feb 5, 2013 | 11:10 AM
blkscls1z's Avatar
blkscls1z
I've had a few. Current is 17" alumastar fronts and 17" RTS rears.
17" CCW rears' that almost match the HRE fronts
18x12 Repros
Old Feb 10, 2013 | 04:22 PM
darkbluez's Avatar
darkbluez
17x11 RTS with Hoosier 315/35/17 drag radials
18x4.5 RTS with M/H Racemaster skinnys
Going with an alumastar on the front this year, and unsure of rears..... may stick with them since theyve cut some pretty good 60' times!
Old Feb 10, 2013 | 08:18 PM
EVL JAKE's Avatar
EVL JAKE
18" fronts?
Old Feb 10, 2013 | 09:47 PM
ShaneFap's Avatar
ShaneFap
315/30/18 Hoosiers.
Old Feb 10, 2013 | 11:55 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Gto spares up front, c5Z rims with 325/35/17 mickey thompsons on back.
325's on c5z wheels rub on standard rear fenders, you need wide body.
I didn't bother with spacers on my front wheels...with the wide fenders it has a funny car look that I like.
Old Feb 11, 2013 | 12:45 PM
RV00GT's Avatar
RV00GT
[IMG][/IMG]
Old Feb 11, 2013 | 02:29 PM
  #33
BT03mach-1's Avatar
BT03mach-1
i just picked up a set of GTO spares. so all i need to run them is a 1.5 spacer to make them flush with the fender? its a z51 if it matters
Old Feb 11, 2013 | 02:30 PM
  #34
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
2" spacer required.
Old Feb 11, 2013 | 02:32 PM
  #35
BT03mach-1's Avatar
BT03mach-1
thanks!
Old Feb 11, 2013 | 02:34 PM
  #36
realcanuk's Avatar
realcanuk
St. Jude Donor '13
http://forums.corvetteforum.com/c6-t...z51-setup.html
Old Feb 11, 2013 | 02:36 PM
  #37
JUIC3D's Avatar
JUIC3D
So 2" adapters if you don't want to grind your calipers, 1.5" if you don't mind grinding them.
To Post up your drag set up
Old Feb 11, 2013 | 02:46 PM
  #38
BT03mach-1's Avatar
BT03mach-1
i will get the 2". they are the same lug pattern right? i read that other post and it says they are different. but everyone else in the world says they are the same LOL
Old Feb 11, 2013 | 02:50 PM
  #39
JUIC3D's Avatar
JUIC3D
Well..they're not exactly the same, but to me, it's negligible. The bolt up great and have given me 0 issues in almost a year and a half of running them. I rarely have street tires on the car and I'm just now down to the wear bars on the spares. YRMV but I have no issues running them straight up.
Old Feb 11, 2013 | 03:25 PM
  #40
BT03mach-1's Avatar
BT03mach-1
thanks. everyone says they are fine.
