need your thoughts on brakes
Brembo is a possibility but what other choices should I consider? I have a 2007 C6 that has the Z51 brake system on it. They were including at the time when I bought the car new in April of 2007.
Also this may be a foolish question but could I replace the front brakes now and then next year replace the back? Brembo or something similar is going to cost $1,200 per wheel. A lot to shell out at one time.
My track time is very minimal and i do not want to get into changing brake pads for track use. I am definably switching the brake fluid to high temp.
Is there was way (even with a spacers) to convert to Z06 brake system? What are your thoughts of a 3/8 spacer. Never used one in the past and do not want to change my rims for a larger offset.
Spacers seem like it is required in almost every type of upgraded brake system. I think Wilwood may be the exception. I really want to go to 6 pistons up front.
Any more thoughts?
Any more thoughts?
I think aggressive pads and high temp fluid are your best bet personally. I do a lot of high speed runs so the bigger calipers were a must.
First thing I would check is to see whether your brake pads are tapered. Here is a picture of the stock C5 and C6 pad showing the kind of taper I am talking about.
This kind of taper will give you a long pedal that increases with the amount of taper. It may not be noticeable on the street but once you start cornering hard you will get some additional run out which will cause the pads to be knocked back more than normal thus giving you more pedal travel. If you have this condition you can combat it by swapping the pads from one side of the car to the other so the outside pad on the left becomes the inside pad on the right side of the car and vice versa for the other set of pads. Swapping evens out the taper. A quick way track guys compensate for taper or pad knock back is to tap the brake pedal with their left foot as they approach a turn. Their right foot is still flat on the floor but they just apply two light taps with the left foot shortly before reaching the brake zone.
That brings us to the next thing. It would be a good idea to check your wheel bearings to see if any of them have too much run out. Excessive run out in the bearings will definitely cause this problem and if you also have tapered pads in combination with a lot of pad knock back your brake pedal could get long quick.
I would also check the calipers and brackets to see if the caliper guide pins are loose and/or the caliper brackets are worn excessively. I had to have the brackets replaced on my C5Z due to excessive wear.
As for pads it sort of depends on how good you are at autocrossing. Stock pads will work fine but I prefer HP+ because they are fairly cheap and also a little more aggressive on initial application so you don't have to hammer the pedal as much.
You should also bleed the brakes and get a good DOT3 fluid in the system. Ford Super Duty fluid (500 deg dry boiling point) works fine even at track events and it doesn't cost much. You could also have air captured in the ABS modulator valve so you might want to have a shop with a GM Tech 2 do the automated bleed which will get the air out of the valve.
Upgrading to an aftermarket brake system should be your last choice. Even the lowest cost ones aren't cheap and if you are currently running in a stock class you will be instantly bumped into a modified class where you will be up against more experienced and cars that have been even more aggressively modified.
Bill
Bill
are these the pads you are recommending for street use and occasional track use
mdh
