LS3 MAF install on LS2 need HELP PLEASE!
Old Jan 22, 2013 | 10:22 PM
CSexy06VY's Avatar
CSexy06VY
Default LS3 MAF install on LS2 need HELP PLEASE!
Hi all, I need help with tuning a ls3 maf sensor on my 06 C6, I installed the stock ls3 air bridge with the maf sensor, but I need to have it tuned.
Please if anyone in the NYC area can help or anyone can give input on which direction to go with this I'd appreciate it.
I have a diablo sport intune, but not HP tuners, do I need to switch to HP tuners?
Thanks in advance
Old Jan 23, 2013 | 06:28 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
You're going to need HP Tuners or similar software.
I got a copy of a Z06 and then pasted the air temp and MAF table into my program and then tuned the MAF.
You also need an adaptor harness or new pigtail and rewire for the blade style sensor.
Old Jan 23, 2013 | 12:30 PM
Don 79 TA's Avatar
Don 79 TA
try getting ahold of Chuck at CoW
Old Jan 23, 2013 | 02:54 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Actually your intune can do it. The problem is you can't cut and past the IAT values in Diablo's software. Let me explain this better, you can change the value but not the break points and they are different between the Delphi(LS2) maf and the Hitachi(LS3) Maf. Call me, I can fix your file and send it back to you. I don't do this for free, but it would cost and hour of time. Huge savings over buying HP Tuners.
Old Jan 23, 2013 | 04:27 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default I'm in westchester.....
Thanks in advance
I'm in westchester..... Very close to you.
Call me if you need anything.
Chuck CoW
914-332-0049
Old Jan 24, 2013 | 10:47 AM
Zip Corvettes
If you want it to work it has to be fixed with intune or else your intune will not be able to be used again. Someone with EFILive or HPtuners can go in and modify the axis in your car and fix the IAT transfer function. If you use your intune to do anything else it will make the axis back to the stock again which will mess up what you just paid to fix.
Old Jan 24, 2013 | 08:56 PM
CSexy06VY's Avatar
CSexy06VY
Which tune would you need from the intune? the stock one or the performance one I load into the ecu?
Old Jan 25, 2013 | 03:43 PM
Zip Corvettes
Keep your stock one, I need the one you are working on and actually installing in the car. Once you send me a copy you will need to rename it so you do not accidentally load it back into the car.
Old Jan 25, 2013 | 10:42 PM
SuperchargedStroker's Avatar
SuperchargedStroker
Just dippin here, but what is the worth of the swap? Dramatic enough to go through all the jazz of tune and what not, it must offer somethin..
Old Jan 26, 2013 | 01:34 PM
ParisTNDude's Avatar
ParisTNDude
That was my thought...why go through all of this? Can't imagine that one or the other has any great performance gains.
Old Jan 28, 2013 | 12:51 PM
Zip Corvettes
It's not really about the MAF sensor, its about the air box. You can't change to the newer airbox unless you make the change for the MAF.
The LS3 vs. LS2 airbox, the LS3 or really the LS7 is hands down better.
Old Nov 28, 2013 | 01:52 PM
CSexy06VY's Avatar
CSexy06VY
So I got HP Tuners, the LS3 MAF sensor, air box and pig tail to install, I have the vararam currently on my LS2 but want to eventually switch to the mamba from zip, that intake is pure gorgeous!!!
What do I need to mod the maf tables in hp tuners?
Old Nov 29, 2013 | 08:15 AM
glenB's Avatar
glenB
log into the HP Tuners website http://www.hptuners.com/ and go to the 'depository' and locate a stock Z06 file and download it. Then open it and copy & paste the MAF & IAT tables. Then tune the MAF to your car.
Old Nov 29, 2013 | 09:35 AM
CSexy06VY's Avatar
CSexy06VY
Thanks for the feedback, I copied one from a 2010 grand sport, and so far the car starts and runs with those tables, is there any other tables that need to be adjusted? Thanks
Old Nov 29, 2013 | 02:10 PM
socal_tom's Avatar
socal_tom
Default I have a 2013 grand sport manual what are some good performance upgrades
I am looking to do a few upgrades but don't want to void the warranty , Ideas guys? So far I only put on flowmaster mufflers . Thanx in advance for the help guys
Old Nov 29, 2013 | 02:14 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Give us a call.....
Give us a call any time and I'll explain some of your options to you.
We've also got some specials running right now that I think you might like.
Thanks... 914-332-0049
Chuck CoW
Old Nov 29, 2013 | 10:27 PM
glenB's Avatar
glenB
Not as far as rescaling the MAF and IAT tables. You'll want to tune the MAF when done and that's pretty much it for that part.
To LS3 MAF install on LS2 need HELP PLEASE!
Old Nov 30, 2013 | 09:26 AM
CSexy06VY's Avatar
CSexy06VY
I did notice that my 06 has a low and high table for the MAF, whereas the 08+ only have one table, and the numbers a slightly off, not by much though. Is there a way to copy the single table and use that instead of the high & low? Car is idling nice, going to test drive it later when I hook up my UEGO sensor to log for my recently installed fast 102
Old Dec 1, 2013 | 12:54 AM
CSexy06VY's Avatar
CSexy06VY
Do you mean the MAF table that relates to the VE? Sorry I'm new to the tuning scene, but I'm getting it.
I copied and pasted the tables from the z06 08, they had the high and low MAF frequency tables
Old Dec 1, 2013 | 06:54 AM
glenB's Avatar
glenB
I copied the High & Low MAF tables and the IAT tables from an 07 Z06and pasted them into my files, an 07 LS2, and then adjusted the MAF tables.
