Ported Throttle Body PROBLEM!?!?
Old Jan 23, 2013 | 10:43 PM
TW14's Avatar
TW14
Default Ported Throttle Body PROBLEM!?!?
Have a 2008 C6. Had the thottle body ported and is now causing some minor issues while operating the car. When I come to a stop the idle begins to slowly climb to 1400rpm and then drop back to normal idle position. Also, when I let of the gas peddle while driving the car it seems like the butterfly is ever so slightly open not allowing the car to slow down while in gear. Also dont get the some back pressure and exhaust noise when letting off the gas. Help would be appreciated.
Old Jan 24, 2013 | 06:07 AM
06CSIX's Avatar
06CSIX
Not normal call whoever ported yours mine ran like stock.
Old Jan 24, 2013 | 06:51 AM
Don 79 TA's Avatar
Don 79 TA
the one from Peak speed in my wife's 05 is fine too
Old Jan 24, 2013 | 07:56 AM
timd38's Avatar
timd38
Is there a vacuum leak?
Old Jan 24, 2013 | 08:30 AM
jon6.0's Avatar
jon6.0
It sounds like they went too far porting it.
Old Jan 24, 2013 | 09:40 AM
ATC399's Avatar
ATC399
Sounds like you need a new throttle body
Old Jan 24, 2013 | 10:28 AM
TW14's Avatar
TW14
I have taken the intire assembly apart and checked it out and re installed. I do not think its a vacuum leak especially since the car was running fine until the TB was installed. I had the GM TB ported by VMAX. I think its ported to much. Sad thing is I spent 12 hours correclty sanding and polishing it and now I will most likely have to do that again.
Old Jan 24, 2013 | 10:55 AM
madmax4499's Avatar
madmax4499
sanding after it was ported?
Old Jan 24, 2013 | 10:59 AM
TW14's Avatar
TW14
Yes, only the exterior surface for finish. The inside port was never touched and was taped off.
Old Jan 24, 2013 | 11:03 AM
madmax4499's Avatar
madmax4499
ok, some have great luck with ported TB, some, like you, not so much. you might need to have a tuner look at it.
Old Jan 24, 2013 | 11:08 AM
TW14's Avatar
TW14
I was informed by my tuner that tuning it is only putting a band aid on the problem which I agree with! The reason I ordered the vmax was to avoid these kind of problems. Guess I will have to start making phone calls.
Old Jan 24, 2013 | 11:38 AM
AVB's Avatar
AVB
If you still have your old TB, put that back on and confirm it is the new TB.
Old Jan 24, 2013 | 11:47 AM
TW14's Avatar
TW14
It was a core exchange. I'm 99% positive if I put the stock TB back on it will eliminate the current problem! Just going to have to get one now.
Old Jan 24, 2013 | 02:23 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I've been running a VMAX ported throttle body for about 5 years with absolutely no problem on my 06. I'd contact VMAX and have them send you a new one.
Old Jan 24, 2013 | 03:07 PM
TW14's Avatar
TW14
Alot of people have the vmax ported TB and runs fine. Possibly I just got a bad draw. I am going to call the vendor and see if he will send me another. If the the problem continues I will be going back to OEM.
Old Jan 24, 2013 | 03:13 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
They took too much out of the blade area. You can tune it out and it's not a band aid. A simple Idle air adjustment will fix the problem. This sounds dumb, but make sure you still have your gasket in between the TB and intake.
I helped a guy out w/ a high idle problem, turns out he forgot the gasket. We all make dumb mistakes like that once and awhile.
Old Jan 24, 2013 | 03:25 PM
TW14's Avatar
TW14
Lol, yeah i have made my fair share of mistakes. But the gasket is still there between the TB and manifold. The car idles correctly just decides to rise to 1400rpm when coming to a stop and drop back down. Find it weird that it idles correctly but is doing that. The car has already been tuned. Not sure that adjustment will help. I have been informed by many they never needed to tune the car after installing a ported TB.
To Ported Throttle Body PROBLEM!?!?
Old Jan 24, 2013 | 03:30 PM
irok's Avatar
irok
tried the Vmax ported tb and car ran like crap. it was untuneable.before trying to tune it it would idle at 3200 rpm.
Old Jan 24, 2013 | 03:39 PM
TW14's Avatar
TW14
Wow, thats no good! What did you end up doing? Did the tune help at all?
Old Jan 24, 2013 | 03:50 PM
irok's Avatar
irok
had three tuners try to tune it. got the idle down but car not driveable.put stock tb back on and all was good. dont know what the problem was but I would actually like to try another Vmax sometime
