75W-140 gear oil
Old Jan 26, 2013 | 02:36 PM
Pitufina's Avatar
Pitufina
Default 75W-140 gear oil
Folks,
I'm experiencing the famous rear end chatter on my 08. I researched some and found that there's a tsb (below) on that. It basically calls for replacing the fluid with the latest GM 75W-90 fluid. Now, I have 3 quarts sitting in my garage of Royal Purple 75W-140 that I was planning to use on my previous build. Do you guys think that this will be too much(thick) to run? I don't want to ruin the rear end. Thanks in advance.
Date: 01-09-2008
TSB: #07-04-20-002A
Document ID# 2048181
2005 - 2008 Chevrolet Corvette
Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns
(Drain/Refill Rear Differential Fluid) #07-04-20-002A - (01/09/2008)
Old Jan 26, 2013 | 02:50 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I don't think you will ruin your differential by using your existing Royal Purple, but if it was me I'd use the recommended GM Dextron LS Gear Oil 75W-90 (which contains the limited slip friction modifier) because I know that it works to cure the chatter. Took care of my chatter as soon as I put it in. (Part #88862624)
Old Jan 26, 2013 | 03:31 PM
Pitufina's Avatar
Pitufina
The RP also contains friction modifiers. I just don't know if these rear ends are finicky in anyway. I've always had mustangs before I moved to the corvette and the 8.8 rear ends are very forgiving and tough. Thanks for the part #. I'll save it just in case, but I rather use what I have since they oil its just sitting in my garage for a while now.
Old Jan 26, 2013 | 03:39 PM
calemasters's Avatar
calemasters
Originally Posted by Pitufina
Folks,
Date: 01-09-2008
TSB: #07-04-20-002A
I would not use 75W-140 in the Corvette. 75W-140 is more suited for something like the Silverado.
I also had the "stick-slip" condition in my differential. The GM Dexron LS (75w-90) fixed this condition.
Old Jan 26, 2013 | 03:52 PM
Pitufina's Avatar
Pitufina
According to the tsb, the base C6 uses 2 quarts. Does that sound right?
Old Jan 26, 2013 | 03:58 PM
JCtx's Avatar
JCtx
You need to buy 3 man. My GS, with fluid cooler, took almost all 3. And remember to start the car in the air (car must be level) and run it in 2nd gear at 15 mph for a minute. Then shut engine off, and top off differential again. If your car doesn't have a cooler, it should still take over 2 quarts, if you drained it properly (car level). Good luck.
Old Jan 26, 2013 | 04:07 PM
Pitufina's Avatar
Pitufina
I think it says 2.11 to be exact for mine since I don't have the oil cooler. Thanks.
Old Jan 26, 2013 | 04:24 PM
ChevyDave's Avatar
ChevyDave
i forget... is that the TSB that says to run car in 8 to 10 slow circle 8's for awhile after ya are done?
Old Jan 26, 2013 | 04:38 PM
Pitufina's Avatar
Pitufina
I didn't see that part. You can look it up under the general section faq's.
Old Jan 26, 2013 | 06:17 PM
REVAK's Avatar
REVAK
Folks,
Date: 01-09-2008
TSB: #07-04-20-002A
I tried several gear oils to cure the chatter. No luck till I tried the updated gm stuff, that was the ticket. Chatter free now for over 4 years.
Old Jan 26, 2013 | 06:21 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
It should be changed every 10 to 15K miles. You will see a metallic sheen in the old oil and be glad you changed it. The new GM oil works great, no noise at all.
Old Jan 26, 2013 | 06:29 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The figure 8's are necessary after the change. They allow the new Dextron to work into the positraction clutches and have the friction modifier do its thing.
Old Jan 26, 2013 | 07:49 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Changing it that often shouldn't hurt anything, especially if you do a lot of track time. But...
On our 2009, I had the diff and A6 fluids changed around 7k. At 50k, I had them changed again and sent samples to Blackstone Labs. They said that both the fluids and the tranny & dif were in excellent condition, suggested I go a little longer next time.
Old Jan 26, 2013 | 08:02 PM
JCtx's Avatar
JCtx
Forgot to comment my diff fluid was absolutely filthy at less than 2K miles. I thought it was black/dark. But when I poured the new fluid, it was basically clear (yellowy clear). Probably contaminated with all kinds of assembly crap, plus break-in metal dust. Not a bad idea to change it at least once initially IMO.
Old Jan 26, 2013 | 10:23 PM
Boomer111's Avatar
Boomer111
As a interesting side note my DTE built differential calls for 75-140 Redline fluid every year minimally.
They do make some changes concerning oil delivery and clutch pack material changes as well as other upgrades with half shafts and some cryo treatment with the ring and pinion gears. I'm not sure how much effect these build changes have regarding the need for heavy oil.
Maybe they just want to keep the gears quite and the heavy oil helps...
Old Jan 27, 2013 | 12:53 PM
Pitufina's Avatar
Pitufina
That's interesting. It's hard to compare with all the changes done. Good information nonetheless.
Old Jan 28, 2013 | 07:14 AM
GOLD72's Avatar
GOLD72
It will take somewhat less than 2 qts on a drain and refill basis for the standard non-cooled differential. I know that for a fact as I have already done my 07 vert several years ago. 2.11 qts would be the amount for a disassembly/overhaul job, i.e., completely dry sump.
To 75W-140 gear oil
Old Jan 28, 2013 | 03:36 PM
Pitufina's Avatar
Pitufina
Good to know since I was already questioning myselfbif 2 quarts would be enough. Thanks.
Old Jan 28, 2013 | 05:07 PM
JCtx's Avatar
JCtx
My car is a '12 GS dry-sump (might be different from a base/vert; I don't know), and I can tell you it took more than 2 before messing with the cooler. Just buy 3, and keep the rest for next fluid change. Otherwise don't let it drain overnight, because you'd be short. And I didn't do anything special: drained the differential with car perfectly level. If you raise the front, you can actually drain a bit more. After doing the cooler, it was almost 3 qts. And I poured the fluid with a clear tube over the rear right wheel, so almost zero waste (just a few drops when it was full). If you have a pump, and a diff. cooler, 3 would be barely enough since it can't suck a bottle completely dry. Good luck.
Old Jan 28, 2013 | 05:16 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
You definitely need to buy 3 bottles if you use a transfer pump, as I did. The pump will retain some after you are done plus if you are like me you are bound to spill a little. I ended up with anout 2/3 of a bottle left over.
