Low beam dead
Old Jan 29, 2013 | 04:18 PM
el es tu's Avatar
el es tu
Default Low beam dead
One of my lowbeams went out recently and I replaced the bulb (which looked like it was in good condition) with a new unit, only to have that one not work.
Before going the route of a new ballast, is there anything else it could be like a fuse specific to the low beam?
Also does anyone know if the ballast can be swapped without removing the whole headlamp assembly?
Thanks!
Old Jan 29, 2013 | 11:33 PM
torquetube's Avatar
torquetube
Sure. Check the fusebox under the hood. #19 is the right low beam, #21 is the left. The fuse positions are labeled on the underside of the fusebox lid.
Old Jan 30, 2013 | 07:25 AM
el es tu's Avatar
el es tu
thanks again!
Old Jan 30, 2013 | 07:40 AM
BadAV's Avatar
BadAV
From what I saw when I swapped my fogs to HIDs, I believe you should be able to pull the ballast from underneath. I pulled my wheels off when I did the swap, just to give more access to that area.
Old Jan 30, 2013 | 07:47 AM
el es tu's Avatar
el es tu
Thanks! This forum keeps me from having to buy another service manual (Ive got a small library from all my old cars)
To Low beam dead
