Magnetic Ride Control Problem
will a tech2 show if the function works or not
well, i am one of those that honestly cant tell the difference. oklahoma has some really bad roads (natural test track) and seriously, no difference on either setting. north of here, ther is a stretch on about 5 miles, where the road is like a bumpy wave, bump smooth bump smooth bump smooth ( you get the idea). no matter what the setting it sounds and feels identical.
we ( wife and i ) could not tell any difference with the goodyears and now with nitto invo we still cannot tell any difference.
we dont road course the car, so havent verified how it acts that way.
i have thought in the past that , had i specifily ordered the option , then i would have wasted the money.
so with that said.. i too wonder if there is some way to test the function.
i have the aweful cold thats going around , so my spelling and sentence structure may be horrible , i feel horrible! lol keep smiling everyone!
a thought... i saw a vid more than a year ago, or maybe it was just a pic. it was a vet going over a road course hill. one version showed with it on and the other pic showed it off. you could see the wheels in the air when off and the tires almost on the road when on.
anyone remember that pic comparision? could you find it? with my cold i dont have the energy to research finding it. thanks!!!!
After I bought it and took it home I found a strip of road that was fairly crappy. Drove through it once on touring and then again in sport. Oh yes, I could tell the difference and touring was a lot less jarring on the body.
anyway, no one said you could have it tested on Tech2. there was a topic that older C5's & before did require a tab/stuffer to be removed (at dealership) but that was discontinued long long ago. So from what i researched, there is really no way to 'test' other than driving and 'feeling' the difference.
generally i think the way most had said to test is the method in #5 & #10...
http://forums.corvetteforum.com/c6-c...e-working.html
I've had two C6's with MSRC - a 2005 coupe, and my current 2009 ZR1. In both cars I found it difficult to tell any difference except in some specific conditions.
I think it only will show a difference when you really drive the car aggressively, and then it will stiffen up and reduce body roll in sport.
There are a couple speed bumps in my area, and if I go over a speed bump with a little speed when in tour mode, after the car bounces up into the air slightly, when it comes back down the ride is soft enough to let the car settle and something underneath will hit the speed bump.
To keep that from happening I just go over the speed bumps in sport. The suspension is firmer and the sport mode doesn't let the car settle quite as fast (or maybe not as much), and nothing underneath bumps.
I find that the ZR1 reacts just the same as my old 2005 did when going over the same speed bumps.
So......it's difficult to tell the difference between tour and sport unless you drive aggressively (like on the track) or over certain types of road surfaces.
Bob
this pertains to an old C5 topic but...
again, only a thought. i do know that 'non usa' versions do have unusual differences. this topic was for C5's and before, but i am including it here for your consideration....
http://forums.corvetteforum.com/c5-g...ck-blocks.html
Finally, even if we don't feel the difference (it's subtle indeed, but definitely a marked difference in bumpy roads), keep in mind these MSRC shocks are a BIG step over the regular ones, since they keep the tires planted to the ground much better, whether in sport or tour mode. They should also be noticeable during quick steering transitions (shocks are not a factor in steady-state turning, like on a skid pad).
I was going to use that exact same example. We have "speed humps" that are long black rubber speed bumps going onto base and if the car is in touring mode the cats used to hit them every time. In sport mode its stiff enough to roll over them at 15-20 with no issues.
Another good example I can use is at high speed. At 150+ the car felt like it was floating up and down at the same rythm on the road in touring mode. In sport mode it feels like its glued down and every crack on the road is felt.
During normal driving you probably wont notice a difference even on a crappy road. It's during high speed handling and large dips and bumps where you really begin to feel how well the sport mode holds the car on the road.
thanks BEZ'r
thats it!
