I just replaced my stock LS2 spark plug wires with a set of MSD wires. Do I need to reuse those metal boot protectors to keep the new boots from being burned up? Or are they even neccesary to have over the MSD boots?
I reused them, figured it wouldn't hurt. They aren't absolutely necessary but you know GM wouldn't include anything extra if there wasn't some benefit. It may depend if you have stock exhaust manifold vs headers.
I didn't use them. The MSD wires have a flexible joint at the plug which allows them to be shaped away from exhaust headers (one of the design features). The heat shields prevent you from so doing. If you are running long tube headers, as I am, It's beneficial to be able to bend the wires for the max distance between wire and header.
I have a LS3 with the stock coil & valve cover set-up.
What is the MSD part# in "black" & what do they go for.
Very important to me:
I want to use the stock metal protectors so do the protectors fit "correctly" on the MSD wires as the stock wires? and if not does MSD make a set that is made to use/for the stock metal protectors. Thanks
The MSD wires bend nicely to clear headers and prevent heat burn. Socks can also be used, but I didn't find it necessary. After a year of use my wires show no heat damage without socks.
MSD boot, 2 years old and it had a heat sock on it, LG headers
This is what it looked like inside when I cut the boot open
This is the terminal after numerous on/offs
It caused a slight miss just off idle as I let the clutch out and what felt like a lean miss between 1500 -2000 RPM, but not all the time and yet it didn't set a CEL, and no, the code wasn't disabled in the tune
1) Ohms on the stock wires matched what they were the first time I ever checked them = 760/770 ohms for all. I have been running the stock wires with the stock metal protectors and 1 3/4" headers for a couple of years now and the plug wires still look & perform the same.
2) One plug had that very small iridium tip missing so I did my first compression test on this engine.
RESULTS:
The three front cylinders on "both" sides were 210 psi and the rear cylinder on both sides were 205 psi using my "gage". Whatever is causing the two rear to read 5 psi lower than the rest most likely has to do with design/manufacturing.
Thanks glenB, the write-up on those Crane wires look good; are you sure that the metal protectors fit well on those wires?
RESULTS:
Five pounds difference is no big deal.
The MSD has a semi angle to them, the Crane wires have a straight boot like the stock wires.
This is the Crane wire. You can see that the Ohms are as advertised and a stock type boot. This is the truck wire BTW
The stock plug boots are still a little different than the Cranes on the site and in your pic. I measured the length of my stock plug wire with it stretched out over a rule and it measures approx. 9 1/2" from boot end to boot end.
I don't know why you would doubt me. I don't know how or where Crane/MSD measure their wires but, the metal sleeve fits, I even gave it a little extra umph to push it through
These are the Crane truck wires. As you can see, even with the coils moved I had enough. These wires replaced the MSD 'made for katech' wires
Bottom line is that it's your vehicle, do as you wish
The stock plug boots don't push through. The end of the stock boot when fully seated into the round metal protector ends near the bottom at the crimped area of the tube which holds the spring in place.
