As some of you know, a HB is a critical part of the engine, so it doesn't destroy itself over time. Hope I don't have to do mine at 50K ('12 GS born 09/15/11 here), but if I have to, would put another OEM for sure. That'd be my last anyway. Better safe than sorry. I just don't quite trust aftermarket 'universal' components when critical, but could be wrong. Have a good one folks.
I know there are a lot of replies here and other places referringto ATI HB.
I looked at that one and decided if I am doing it, I want it to be there forever.
I went with Jegs. It is a CNC'd piece of steel instead of the ATI which is aluminum.
Nothing will ever damage the steel HB where the Aluminum could wear over the miles.
I don't plan on ever doing an HB replacement ever again on this car.
the ATI hb is not aluminum but is the Rolex watch of hb for LS engines
the ATI is not a universal component and the oem hb would not be in the same ballpark as this precision CNC'ed piece of equipment. if you replaced your oem with another oem you may be doing the job over in the next 50 miles. the oem is that bad!
The ATI balancer is also available in steel for the LS2. Part #917246.
