dyno is way low
Old Feb 8, 2013 | 08:39 PM
titleist's Avatar
titleist
Default dyno is way low
ok just got off the dyno and pulled 414/419.
this is with a 233/239-112
fast 102
long tubes ( no cats)
stinger exhaust
CAI
this is an LS2 car with low miles.
with long tubes and a CAI it pulled 380/383
anyone see a problem with this?
the cam has 14* of overalp and sounds damn near stock
opinions?
Old Feb 8, 2013 | 08:41 PM
Shoaf85's Avatar
Shoaf85
Same Dyno?
Old Feb 8, 2013 | 08:42 PM
jon6.0's Avatar
jon6.0
I only made mid 420's with my old LS2. Kooks 1 7/8 headers, no cats, full 3" exhaust, FAST 90, Volant CAI and a 242/248 111lsa cam. Your numbers seem realistic to me. Go run it and see what it MPH's.
Old Feb 8, 2013 | 09:31 PM
narfdanarf's Avatar
narfdanarf
What kind of dyno? What is it tuned with? What was the actual timing? Those numbers are pitiful and pretty suspect with a cam that large and making more torque than hp?
Old Feb 8, 2013 | 09:44 PM
titleist's Avatar
titleist
yea the TQ being higher than the HP is strange to me. never seen this with a cam only car.
dynojet dyno
with 14* of overalp i thought this thing would sound like a dragster. but it sounds like a hot cam.
something has to be wrong here
Old Feb 9, 2013 | 12:43 AM
narfdanarf's Avatar
narfdanarf
Maybe the grind was just wrong. I know this may sound dumb but are you sure you put the bigger cam in it? The numbers would seem right for a car on stock cam with all those mods and no cam.
Old Feb 9, 2013 | 09:32 AM
titleist's Avatar
titleist
i agree completly. thats why i am so confused here.
these numbers sound exactly like what you should get with all mods except the cam.
the cam was new in the box and i just looked at the old cam. it has marks from being used. so i must have put in the new cam.
if it was degreed wrong would it have this effect?
Old Feb 9, 2013 | 11:26 AM
Pitufina's Avatar
Pitufina
What are the specs? Custom? The cam may have been cut wrong, it happens. Or degreed in wrong.
Old Feb 9, 2013 | 03:35 PM
titleist's Avatar
titleist
233/239-595/603 112
how could it have been degreed wrong
Old Feb 9, 2013 | 04:00 PM
Pitufina's Avatar
Pitufina
233/239-595/603 112
Did you just installed dot to dot or used a degree wheel to confirm the cam timing events?
Old Feb 9, 2013 | 05:04 PM
titleist's Avatar
titleist
dot to dot
Old Feb 9, 2013 | 05:05 PM
titleist's Avatar
titleist
is it possible to have the wrong cam?
this is a considered on the large side. and the damn car drives like stock. somehting is wrong for sure
Old Feb 9, 2013 | 05:14 PM
sallen619's Avatar
sallen619
Phil at AI told me it happens all of the time...thats why he offered to measure my cam for free (I just paid for the shipping). The cam was spot on (Thanks Kevin a Schneider Racing Cams).
As far as dynos go, my first dyno got me 314 rwhp...bone stock (mainline dyno)!!! Its just a tool...
Old Feb 9, 2013 | 05:21 PM
titleist's Avatar
titleist
my concern now is the investment of putting in the cam, tuning, PITA, etc... now i have to do it all over again if the cam is wrong?
Old Feb 9, 2013 | 05:28 PM
sallen619's Avatar
sallen619
I hear you...I think you should find different shop and just do a dyno run. See what numbers you get and go from there.
Old Feb 9, 2013 | 05:38 PM
old motorhead's Avatar
old motorhead
That cam, as specced, isn't in your motor. As specced, it will sound and behave WAY different vs stock. I have a Comp cam that is going on a cam doctor next week. It's a mild boost cam that sounded OK, but made very little power. The measured boost is 3 to 4psi over what I thought it should be. I know it's not what I ordered. Big boost and little power.....hmmm.
Old Feb 9, 2013 | 06:24 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
wow! been researching differant cams and that one should make some good power gains...
To dyno is way low
Old Feb 9, 2013 | 08:06 PM
titleist's Avatar
titleist
just tore it apart and checked. it is degreed correctly and looking ok. i think the cam was ground bad.
now what?
Old Feb 9, 2013 | 08:10 PM
Cherokee Nation's Avatar
Cherokee Nation
Hummm?
Old Feb 9, 2013 | 08:16 PM
titleist's Avatar
titleist
seriously need some help here
this thing doesnt even drive like it has a cam in it.
