LS2 Manifold removal.
To make things as complicated as possible. I'm running Z06 manifolds on a 2007 LS2 with an A6. I'm swapping over to come Kooks and am having a little trouble pulling out the passenger side manifold. I'm thinking the starter cables might are in the way. Is there anything else I'm going to run into? Should I pull the manifold apart at the cat?
Thanks!
J
Thanks!
J
