question about valve spring install (Brian Tooley kit)
Old Feb 9, 2013 | 07:30 PM
turbotuner20v's Avatar
turbotuner20v
Default question about valve spring install (Brian Tooley kit)
Here are the specs on the springs:
.660" Lift Dual Spring Kit for LS engines using stock rocker arms. Includes dual polished springs, matching titanium retainers, your choice of locators for stock or bronze guides, locks and seals. Spring specs are 155 lbs @ 1.780", 380 lbs @ 1.180", 400 lbs @ 1.130, coild bind @ 1.070" This is a drop in spring kit for the following engines: LS1 LS2 LS3 LS4 LS6 L76 L92 L99 LQ4 LQ9 L33 LSA. This kit will not fit LS9 engines.
When measuring the height from the locator to the retainer, I got a maximum of 1.755 when it should be 1.780.
Will that matter for my application?
