Just look at the fastest times NA & BOLT/ON LS2 LS3, and you will see that Vararam is the fastest, shows the most gains. and its been on my car since 2005 37,000 miles never hydro locked, and its shinny black plastic looks the same as any other CAI black shinny plastic
Sorry, but that much for an intake is absolutely ridiculous, especially when there are tons of intakes for the C6 that do the job only slightly worse or just as well.
Just depends on what you are looking for. If you want quality or cheap plastic. I mean the speed limit is 70mph and Honda Civic will do that with even a little performance, but you chose a Vette. Glad you did because that is the business I am in, but it is each his own and some people want the quality. I do not know much about LG's box, but we make our own Mamba box and I can tell you between the Carbon and the process to actually make it is very time consuming and extremely expensive.
I don't doubt that, but the fact of the matter is 1800 for a mild performance gain is ridiculous, when a Vararam will do the same job. If you're going strictly for bling, fine, but I can't justify that price.
I call shenanigans.
Price is not a direct reflection of quality; especially in the corvette market.
These days quality carbon fiber pieces can be produced at near the same prices of plastic; if you are making them in house, by hand, then yes it will be expensive and time consuming, if you are having them produced in an automated vacuum machine in china, like everyone else, then they will be cheap to produce in quantity.
And don't or one min. try to pull the china = crap line, the overwhelming majority of aftermarket Vette parts are made in china, including just about every name brand intake, header, exhaust, carbon fiber products, etc. etc.
A true "cold air" intake will require you to cut the radiator shroud, and should be tuned. All the others mentioned just replace the filter and do not access air from in front of the radiator.
First, there is no "automated" production of carbon until you get to the OEM level and they spend millions. Our air box is as automated as one can get in that the pattern is cut by machine. After that it is a person doing everything. For one the carbon is allot more expensive because it is called prepreg and it is not your run of the mill carbon that someone would purchase doing a wet layup. Second that vac machine is called an autoclave and for a decent one they start at about 100k. So all of these tools that are required to build a quality box get absorbed into the price of the box. No plastic is no where near as expensive until you go the level of OEM and do a injection mold peice. While the part itself would be cheap the tool would be around 250k. You are comparing apples to oranges and there is a quality difference. Performance difference also depending on the box, I can show you where the plastic would leak over time as compared to the carbon. It is always bling at some point, I like to use chrome wheels and tail light covers. Do they add any power? just bling. To each their own.
Not true, 99% of the headers are made right here in the US and you can walk through there entire production in their facility. The same with the exhaust systems. Now carbon hoods would be the exception, the ones I have seen as of lately I do not think they are being done in the US and more than likely in China. On those headers, even the stainless is being produced in the US.
