Ignition switched 12 volt lead
Old Feb 11, 2013 | 12:38 PM
trbochrged's Avatar
trbochrged
Default Ignition switched 12 volt lead
I just purchased a direct wire kit for my radar detector. After probing the fuse box under the passenger foot area, I'm not sure where to tap into a switched 12 volt source. The lighters in the car seem to stay energized even when the car is off as does the red with white stripe wire leading to the radio. I don't want to have to turn the detector on and off. I also don't want to kill the battery.
Old Feb 11, 2013 | 12:47 PM
ChevyDave's Avatar
ChevyDave
if your going to install it under mirror, folks have been using the mirror power.
click and open.. http://forums.corvetteforum.com/atta...6-corvette.pdf
see #6... http://forums.corvetteforum.com/c6-c...or-wiring.html
EVRose's Avatar
EVRose
Wipers or heated seat circuit. They both turn off with ignition.
Old Feb 11, 2013 | 01:01 PM
trbochrged's Avatar
trbochrged
It is under the mirror, but I have the smart cord live unit under the dash
Old Feb 11, 2013 | 02:57 PM
WasVette's Avatar
WasVette
Ditto EVRose - Wiper circuit under passenger footwell. Insert wire under fused side (not hot side) or use a mini fuse tap.
Old Feb 14, 2013 | 01:19 PM
trbochrged's Avatar
trbochrged
Default Thanks
This is why I Paid for a lifetime membership to this forum. We all need to support this site as it is a very helpful tool.
Old Feb 14, 2013 | 06:36 PM
JCtx's Avatar
JCtx
You should have bought a 'mirror tap' wire buddy . It's also sold as 'invisicord'. You don't have to run any wires thru the A-pillar covers. Plus those folks (BlendMount) make an awesome radar detector mount, which many of us use.
But if you insist on using the fuse box, buy a $10 'add-a-fuse' at your local auto-parts store, and use the seat heater fuse, which is rarely used. Good luck.
Old Feb 14, 2013 | 06:39 PM
trbochrged's Avatar
trbochrged
Default ????
Already installed. The mirror tap won't work with the Escort live cord.
Old Feb 15, 2013 | 01:48 PM
corvettej's Avatar
corvettej
St. Jude Donor '13 thru '24
Do the tap at the wiper fuse thats where I placed mine for my radar detector and Escort Live, go to Autozone , orielly or advance auto and get a "Mini Add a Line" it cost between $5-7 dollars, thats the way to go with a protected circuit.
To Ignition switched 12 volt lead
