Banging from under car!
Old Feb 11, 2013 | 04:59 PM
jcalvin's Avatar
jcalvin
Default Banging from under car!
So, I have a 2006 z51, pretty much stock everything. When I am driving down the road, i get a banging noise coming from underneath the car. Sometimes it happens when I am hitting rough road, sometimes not. It happens when I'm turning, sometimes not. I've looked at all of the suspension, and from what I can tell, everything looks fine. Has anyone else had any issues similar to this with their car? It sort of sounds like it is coming from the front left of the car, although it is hard to tell. It doesn't make the noise with the vehicle stopped, or even when turning the steering wheel when stopped. I can sometimes feel its vibration through the floorboard of the car through my feet, but not all of the time. Any ideas of what I should check out would be greatly appreciated!
Old Feb 11, 2013 | 05:09 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
Sounds like the sway bar end links are bad or loose. You cannot tell if they are loose just by looking at them. You need to get under there with the wrenches and tighten them good. Had the same issue on my cars.
Old Feb 11, 2013 | 05:10 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Yeah, it can be hard to tell where a noise is coming from. Might the exhaust be hitting something?
Old Feb 11, 2013 | 05:16 PM
jon6.0's Avatar
jon6.0
Sway bar end links. They need to be REALLY tight or you get the bang/pop sound when turning or on rough roads. My car just did it after my exhaust install. We removed the rear sway bar and did not tighten it enough upon reinstallation.
Old Feb 11, 2013 | 06:11 PM
JerryTX's Avatar
JerryTX
Torque tube
Old Feb 11, 2013 | 08:55 PM
VET4LES's Avatar
VET4LES
Check the exhaust. Their are springs holding it up in the middle and they can come off or break. Mine did and it was an easy fix.
Old Feb 12, 2013 | 02:52 PM
carpe dm's Avatar
carpe dm
Good place to start; check the bushings and lube them with some synthetic grease..... worked for me.
To Banging from under car!
