100w fogs
Old Feb 13, 2013 | 10:14 PM
ROID11's Avatar
ROID11
Default 100w fogs
will 100w yellow bulbs burn out the fog light wiring? or melt housing?
Old Feb 13, 2013 | 10:25 PM
MBB's Avatar
MBB
Why in the heck would you want to run 100w fogs? It's been my personal experience that the housings on most cars melt with anything over 35w. But 100w is just blinding. All of my friends that have gone 100w have removed them because they are just too intense.
Old Feb 14, 2013 | 01:33 PM
Don 79 TA's Avatar
Don 79 TA
also because of overpowering the wiring harness
more often than that, that's the culprit of fire issues and others
i upgraded the ones in the wifes car with PIA's
not super bright, but made a very nice addition and clean white light too
forgot offhand what bulb/part number
i'd look into that, unless you need amber lights
also a 100w bulb may burn out to fast from overheating if you dont get enough air to keep it cool
Old Feb 14, 2013 | 06:28 PM
Bedouin's Avatar
Bedouin
An interim option is yellow lamin-x...one 12"x12" sheet will cover both lenses.
Old Feb 15, 2013 | 11:56 AM
cclive's Avatar
cclive
Remember that a 100 watt bulb is using about 9 amps of current...so the two will be at least 18 amps. This can also hurt the relay that runs them if it is not made for that much current.
Old Feb 15, 2013 | 12:25 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
For my HID fogs and high beams I used dedicated high amp circuits and utilized the stock wiring as the trigger for the new relay. In other words the original connector just turn on a relay and the new fused 10ga circuit is direct from fuse box + to each bulb
Old Feb 15, 2013 | 12:31 PM
cclive's Avatar
cclive
This is exactly the right way to do it.
To 100w fogs
