Hey everybody , long time reader , first time member , im getn ready to do H/C on my 06 , already purchased ls3's and hav been reading on here bout different results , was planning on milling but don't wana fly cut , I have saw the list of the cam specs from guy's doing this swap , I wana go as big as possible without PTV problems , are most of the results with fly cutting or without ?? Car is auto , gona do a stall also , any info would be greatly appreciated THANKS
A lot of things play into how much cam you can get away with(cam timing events,lift.etc). When I took the stock ls3 heads and switched to CNC with manely valves, I lost .023 PTV clearance. My cam is decent size but I fly cut .060
and your really the only LS2 to LS3 head swap that's flying in a C6
I have a 2006 coupe and just had a new Ls2 built with the ls3 topend. I didnt flycut or mill the heads. Texas Speed has a new cam out for ls2 with ls3 topend. It's the biggest cam you can get without flycutting. It's a 235/239 .641/.615. Special lobes give it more PTV clearance. I have a 3200 vigilante stall in mine and this setup runs like a scalded ape.
I have a 2006 coupe and just had a new Ls2 built with the ls3 topend. I didnt flycut or mill the heads. Texas Speed has a new cam out for ls2 with ls3 topend. It's the biggest cam you can get without flycutting. It's a 235/239 .641/.615. Special lobes give it more PTV clearance. I have a 3200 vigilante stall in mine and this setup runs like a scolded ape.
rough numbers on my cam are 231\240 617\613..so yours is pretty decent sized in my opinion
Just go ahead and fly cut the pistons, not a big deal. I had this done on my Z06 if u remember.
I think I'm like everyone else being unsure of what is all involved in the fly- cutting. Is this something that can be done at home or special tools and shop required.
It's is the sticky above. Spin monster does a great job documenting and even has the tool for rent last I knew.
as others said.. It's really no big deal.. Spin has a great write up.. took me about an hour when I did mine.
I fly cut the pistons. Best mod I have done to date. Car picked up an honest 40 rwhp from just the heads and intake on a before and after pull on the same dyno.
