Launching techniques
Old Feb 15, 2013 | 06:48 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default Launching techniques
I am looking for advice from those who have extensive seat time at the strip on the best way to launch. Since adding 75 RWHP with bolt ons to my LS2 manual Z51 I find myself breaking the rear tires loose with any spirited acceleration. I've tried slipped clutch launches and dropped clutch launches at various rpms but can't seem to find the right method to minimize wheel spin and get the best acceleration times. I know drag tires would help but aside from that? Having no seat experience at the strip, I'd appreciate any sharing of your best results from those who do have seat time there. Thanks.
Old Feb 15, 2013 | 07:36 PM
Justasheet's Avatar
Justasheet
You need to PM Joe_G
Jeff
Old Feb 15, 2013 | 08:16 PM
sallen619's Avatar
sallen619
Find a launch RPM that doesn't let the car bog...don't give it more gas until the wheels get some grip...
Old Feb 15, 2013 | 09:33 PM
ParisTNDude's Avatar
ParisTNDude
The infamous Ranger made a bunch of YouTube video on launching techniques using his Z06. Do a youtube search or go to Rangeracceleration.com. I'm sure you'll get some good tips from the best.
Old Feb 15, 2013 | 11:02 PM
HOXXOH's Avatar
HOXXOH
Tires need to be matched to both the power and surface. I think you have already recognized the problem, so now it's a matter of choosing the right ones for your application.
Old Feb 16, 2013 | 12:52 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Default The best results with whatever tire you have on the car.
DITTO.
However let me add a little something to it.
LAUNCHING THE CAR:
1) Depending on your cars power launch at a "rpm" that does not bog and if you are a little off, than a foot or two of wheel spin is preferred.
2) Knowing "your" cars power level (all are different) go down on the gas pedal as quickly as the tires and power level will allow from the launch; sticky tires will let you instantly floor the throttle and with not so sticky tires you will have to practice to find the fastest pedal depression rate to not get the tires spinning but get the very best acceleration possible.
PS: It's all over in a second or so!
Old Feb 16, 2013 | 01:39 PM
JCtx's Avatar
JCtx
Originally Posted by Grand Sport Man
LAUNCHING THE CAR:
And all of that with a quick release of the clutch pedal OP, in case it wasn't obvious. Better to work on throttle control than riding the clutch IMO. That's pretty much what launch-control does. Good luck.
Old Feb 16, 2013 | 04:17 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Old Feb 16, 2013 | 04:37 PM
Audacious Nick's Avatar
Audacious Nick
http://forums.corvetteforum.com/c5-z...echniques.html
Old Feb 17, 2013 | 08:52 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
There's no sense trying to teach someone to ice skate when they are wearing sneakers.
You need to get drag radials then we can dig into the launch technique. Launch rpm...bog...none of these things matter when you are running street tires. With street tires you have only one goal. Don't spin your tires. Best plan is to stay in the stands.
If you really want to run street tires, then I'd say let the clutch out like you do on the street then ease into the gas as quickly as you can without spinning.
If you spin the tires, you risk wheel hop and breaking the rear end, or losing control of the car.
If you do go sideways on the track, let out of the gas. You should be able to regain control; if you stay in the gas your chances of missing the wall are greatly reduced.
Old Feb 17, 2013 | 10:50 AM
HOXXOH's Avatar
HOXXOH
I don't believe the OP said he was at the track. If he's just wanting to practice in a parking lot or driveway, then the key is to use the same exact spot to learn technique. The knowledge gained can be transferred to the track. If the tires or surfaces change, the adjustment time is less.
One thing is for sure. Practicing on the street, where the surface changes at every stoplight, won't teach you much.
Old Feb 17, 2013 | 07:16 PM
azZ06Mike's Avatar
azZ06Mike
St. Jude Donor '11
Taking lessons from HOXXOH will make you slower and break! Especially since he is an auto car that has blown up from shifting a auto wrong.
The key in a six speed is a combo of track condition,tire pressure and clutch ability. I found on 540 rwhp z06 that slipping about 10 feet out of the starting box at 3500 to 4500 rpm at 18 psi has always worked at the track. As for the street i just installed Nitto Nto5r drag radials and they hook great out of the box at 32 psi!
Old Feb 17, 2013 | 08:48 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Thanks for the referal to Ranger's tips - very informative; and thanks to everyone elase for your input. All, posts are very much appreciated.
Old Feb 18, 2013 | 08:25 PM
1fastbob's Avatar
1fastbob
Good Point.
To Launching techniques
