A friend of mine is installing an ARE 4 stage dry sump system on his C6 LS3. The pump mounts where the air conditioner compressor would be. The 4 stage pump is very long and interferes with the passenger side motor mount (the piece that bolts to the block). This requires removing a lot of material from the stock motor mount.
Does anyone know of an after market mount that would fit while still maintaining the required strenght?
Thanks for any thoughts. ;-)
discusses that they have done several ARE setups with either stock or coilover suspensions. I'm sure he could get you straightened up; as it sounds like an install he's done a few times. GL.
