Service Charging System caused by starter?
Old 03-01-2013, 04:51 PM
bcmvette
bcmvette's Avatar
Default Service Charging System caused by starter?
I have a "Service Charging System" notification on my dash and the Autozone test shows that my battery and alt are fine while my starter is low voltage - "starter amp draw is low (0Amps) with ok starter voltage (10V) - check starter circuit for loose, worn, or corroded wiring" is what it says on the report.
Some questions:
1. Could this be causing "service electrical system" on the dash?
2. Do I need stands to get to the starter? The car has aftermarket headers. I've seen some guides that say it should take about an hour but I haven't started poking around to see if headers make a difference.
3. Can I check the wiring/connections/nuts/etc without removing anything?
Any tips would be awesome, thank you.
Old 03-01-2013, 05:13 PM
ChevyDave
Support Corvetteforum!
ChevyDave's Avatar
Are you running aftermarket spark plugs? If so, what kind?
Check the wires on your starter. They could be corroded , loose , burnt.
1) yes
2) unless you are very very slim, yes (jack/lift and stand for SAFETY)
3) yes , disconnect battery (or dont wear a ring , and just look and wiggle test) and inspect connections for burnt/loose/corrosion.
ok, i'm adding this. does your horn honk? if no, check the horn fuse in engine compartment fuse box.
Old 03-01-2013, 08:24 PM
VET4LES
VET4LES's Avatar
This is what the wires on the solenoid look like.
To Service Charging System caused by starter?
Quick Reply: Service Charging System caused by starter?
