2009 c6 2800 stall question
Old Mar 3, 2013 | 12:25 PM
c6 376's Avatar
c6 376
Default 2009 c6 2800 stall question
I just want to know if its worth it
vigilante 2800 stall or 3200 yank
Old Mar 4, 2013 | 12:22 AM
LS1LT1's Avatar
LS1LT1
They're both good for that 'mostly street driven only car that sees some drag strip duty' scenario.
I have a Vigilante 3200 in my C6 and it's a great converter. I had considered swapping it out for a higher stall converter (likely won't do it now though) but those 'looser' type converters aren't for everyone.
Old Mar 4, 2013 | 12:40 AM
ShaneFap's Avatar
ShaneFap
if you're doing it i would recommend a 3200-3600.
Old Mar 4, 2013 | 11:04 AM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
As with most other mods, it comes down to the question of "what are your goals?".
Old Mar 4, 2013 | 05:25 PM
c6 376's Avatar
c6 376
Will I like the 2800 TC on the street but the car is not my daily driver
I know I will love it at the track
Will I need to retune the A6 whit 2800 stall
I have other mods on the car my best at the track 11.89
What should I expect from a stall.
THANK YOU
Old Mar 4, 2013 | 07:31 PM
jpee's Avatar
jpee
I have an 05 with an FTI 2800 converter, and a few other add on's (Kooks Headers, Vararam, Tune by Cartek..
I just ran my best ET yesterday 11.61 @ 118 mph at Atco NJ.... The 2800 is great for the street, & I'm getting 1.6x 60' times...with Nitto Drag Radials...
Old Mar 4, 2013 | 08:39 PM
c6 376's Avatar
c6 376
Do you have a trans cooler
I was told a trans cooler is a must whit a stall
Did you use HPtuner for shift points and trans tune
THANK you
Old Mar 5, 2013 | 12:55 AM
jpee's Avatar
jpee
THANK you
Yes I have a "Stacked Plate" type of trans cooler..and YES it's a damn good idea to use a cooler if you are going to put in a hi stall converter!!
NO I don't believe you get the "most" out of those "canned" tunes.. I brought my car to "CARTEK" in NJ and they had it on a dyno to tune it and its making about 400 hp to the rear wheels now...
The shift points were also set by Cartek... set to 6500 it seems to be best...
Old Mar 5, 2013 | 08:14 AM
Polar Jet's Avatar
Polar Jet
It's all a matter of preference and what your goals are. I would say that if your car is not a daily driver you might want to go higher than a 2800. My Pro Torque 2800 in my LS3 feels and drives like stock which is how I wanted it this time around.
I think you should look closely at the Yank 3200 or 3600.
Old Mar 5, 2013 | 01:14 PM
c6 376's Avatar
c6 376
Thank you for all the info
I just ordered my stall 2800 and a trans cooler
I will install it next week.
I just cant wait to take it to the track
Old Mar 5, 2013 | 04:06 PM
Supporting Vendor
Sorry I didn't respond to this sooner but unless you're only hoping to pick up 1-2 tenths at the track I don't think you'll be very happy with a 2800 stall. A Yank SS3200 would have been a better choice or even an SS3600 which still drives great on the street with stock 2.56 gears.
Old Mar 5, 2013 | 04:38 PM
c6 376's Avatar
c6 376
THANK YOU subfloor
I think whit 2800 stall and a good set of headers I should be able
to pick up 3-4 tenths
do you think the headers will wake up the car.
JP performance told me a 2800 vig feels more like yank 3200
I just hope for good result at the track something like 11.60
whit good tires
Old Mar 5, 2013 | 05:56 PM
jpee's Avatar
jpee
I picked up .4 tenths by going from a stock converter, to a FTI 2800
I'm at the point now where if I go to a higher converter, I'm going to have to get bigger/better drag radials.. & I DON'T WANT TO..
I'm using Nitto 555 305/35x18" and with the stock converter my 60' was about 1.96 - 1.98 with just going to a FTI 2800 I'm going 1.62 - 1.65 for my 60'
I still will spin if I don't heat them enough....
Old Mar 5, 2013 | 08:48 PM
speedraider's Avatar
speedraider
can't wait til my vigilante 2800 goes in.
Old Mar 6, 2013 | 03:57 PM
Mike Farris's Avatar
Mike Farris
Got a Vigilante 3000 multi-disc installed last week. Its a little rough when locking/unlocking. I ran some 1.75 60' with the stock converter, anxious to see what it runs with this bad boy.
What kind of tuning changes are necessary with a new converter?
Old Mar 6, 2013 | 06:39 PM
c6 376's Avatar
c6 376
I ordered vig 2800 single-disc its suppose to feel like stock TC
after installation Iam going to the dyno for tuning and my tuner
is going to ajust the shift points.
To 2009 c6 2800 stall question
