Z06 manifolds are a good mod for you. You will get good gains from them. Check Hoxxoh posts or pm him as he had them when he set the ls2 bolt on record a while back.
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Originally Posted by Joe_G
Wouldn't bother with a ported intake then.
So keep the stock headers for smog inspection and aftermarket in the time between.
I lived in SoCal when I bought mine and hated not being able to mod as much as I wanted. I say just do it during the times when you wont need the inspection and enjoy the ride
Not going to deal with changing headers every 2 years... thats a PIA..
Im sure I can get a smog, but really dont want to deal with it..
rather do it once and be done with it.. thats why im looking for z06 parts.....
Personally, IMHO the headers are such a good gain (Hoxxoh went to them) that if you are really into performance it's worth swapping. It's easy on our cars.
On a stock LS2, customers generally see about a 20 rwhp gain from our Radical porting and 14 rwhp gain from basic porting of their LS2 intake manifold. Here is a link to a thread that will give you more information: http://forums.corvetteforum.com/c6-p...-in-stock.html
You can also go to our website to see the difference between Basic porting and Radical porting. http://www.peakspeedshop.com/
I had installed a ported intake manifold on my 2005 LS2 with only a tune and Vararam CAI. Nice improvement in throttle response and the butt dyno said more torque. Never had it on the real dyno, but it definitely made a difference that you could feel in throttle response which is what i was going for. I would do it.
Like the title says.. What kind of gains do you think I would see on a ported LS2 intake... Only mods are Halltech CAI, Vmax ported TB, and a tune..
Thanks all...
There were some b&a dyno numbers on a ber ported intake which showed 7 hp (just a tad lower than the FAST intake). That was bone stock to BER I believe. Go Here and read back: http://forums.corvetteforum.com/c6-p...fold-sale.html
Question I have, is whether that hp increase from the ported intake is additive to what you get from Halltech's (or anyone else's) CAI? I'm guessing it isn't. Air is air whether your getting it from CAI or intake ports. I'd get the answer to that before you spend your money on the intake and probably what could be a new tune.
Once you've swapped the headers out on an ls2/ls3 you could do the job again in a fairly quick fashion. Hell give the neighbor kid 100 bucks or your son and give them the ability to say they worked on a corvette and have some cash for the weekend if you don't want to do it yourself.
I myself will never own a sports car without a full exhaust and intake. It really wakes up the car. Hp numbers are good, but it's the all around experience. The car responds better, sounds better, and driving it becomes much more of a joy.
And after having a c5 for 5 years with a full exhaust and buying a stock c6...I can tell you first hand that the c5 was much more fun to drive till I threw on the exhaust on the c6
Just for something to think about. all sorts of data on the ls2 intake on ls1tech.com.
Junk. I have modded c5s for a long time. Heads, cams, intakes headers etc. Of all the ls1 intake upgrades, the ls2 intake is at the bottom of the list. Matter of fact, a c5 zo6 intake makes more power than an ls2 intake.
I have longtube headers, xpipe, vara ram 2. Can't wait to get rid of this ls2 intake. Ported fast or a custom Wilson is on my list.
You are right in that the unported LS2 manifold is terrible. However, it responds very very well to porting and a ported LS2 manifold performs better than the LS1 or LS6 manifold. The primary reason is that the LS2 manifold is constructed of 3 pieces that are sonic welded together. Where the pieces match inside the runners is very rough. Porting smooths out those transitions for much better airflow.
Good info. I think ill do a couple dyno pulls. See where I'm at. Then do a home port jobaddressing the areas you mentioned. Re dyno and see how it goes.
After I do my wide body rear this month, I'm going to supercharge. Do you think a ported ls2 Mani is going to be safe for the boost?
Yes, ported intake will be safe for boost (if porting job is'nt messed up). Even our Radical ported manifolds stand up to boost if you want to try to get as much out of your stock manifold as possible.
