PCV Setup - Concurrence/Feedback Desired
Old Mar 4, 2013 | 01:29 PM
JuicedH22's Avatar
JuicedH22
Default PCV Setup - Concurrence/Feedback Desired
So, after doing the research (a lot of conflicting stuff out there) I think this is how I want to do my PCV system, but was hoping for feedback from the 'experts'....
The thought behind this is that the valve covers will be the 'breathing' side of the system holding at or near atmospheric and the crankcase side would be held at a negative dP (lower pressure) being on the suction side of the intake.
The other differences/considerations were to have an oil cap breather filter (came with the Holley VCs I bought) and/or instead of a filter on that catch can, have it route to the intake side (pre "maf" I have in quotes since I no longer have a maf)... which theoretically is also atmospheric pressure. I have a NW102mm DB throttle body, so there is no routing to that 'port'.
Thoughts? Opinions?
Old Mar 4, 2013 | 01:32 PM
JuicedH22's Avatar
JuicedH22
Application is an n/a 416 LS3 stroker with a 200 shot.
Old Mar 4, 2013 | 03:54 PM
turbotuner20v's Avatar
turbotuner20v
That diagram is fine, that's what I run on my setup (but with a check valve since it's FI)
To PCV Setup - Concurrence/Feedback Desired
