Brake Rotor Question?
Old Mar 4, 2013 | 09:04 PM
Super Red's Avatar
Super Red
Default Brake Rotor Question?
Can Z06/GS stock drilled rotors be turned on a lathe to get rid of ridges and trued? Or are they use once and replace type rotors.
Old Mar 4, 2013 | 09:25 PM
cclive's Avatar
cclive
The holes make that a bad idea as it would ruin the radius at the entrance to each hole. That radius is important to minimize cracks starting there. Most brake manufacturers do not recommend turning rotors any longer anyway, as it just makes them thinner and more likely to warp afterwards..
Old Mar 4, 2013 | 11:39 PM
HOXXOH's Avatar
HOXXOH
They can be turned, assuming the operator understands how and has experience prior to yours. Interupted cuts are not something for amateurs.
Old Mar 5, 2013 | 11:40 AM
cclive's Avatar
cclive
100%. Taking off any material will cut off the top of the radius at each hole, increasing the chance of a crack starting there. The holes are already the source of cracks beginning, even with proper radiusing. This is why drilled rotors are not used on real race cars. Here's a post from BEZ06 showing some problems...
http://forums.corvetteforum.com/1583086034-post18.html
Old Mar 5, 2013 | 12:05 PM
Super Red's Avatar
Super Red
Thanks everyone for the comments. Was at VIR last fall and afterwards pulled the Hawk pads off and noticed some small cracks at the holes. Put a new set of stock rotors on, so though maybe I could resurface the old ones and use them at the track. But, I think its time for some slotted DBA's for the front. Again, thanks for the advice.
Old Mar 5, 2013 | 06:26 PM
tripleblack05's Avatar
tripleblack05
Default 2005 Z51 Brake Rotor ????
Does anyone think we should use aftermarket rotors with no holes? I need to replace my Z51 rotors and am curious if I should go back with GM factory rotors or some aftermarkets.
Thanks for your response, I am a new vette owner and have learned so much from all of you.
Old Mar 5, 2013 | 06:57 PM
cclive's Avatar
cclive
No, the bling looks good and as Bob BEZ06 said, you will not overdrive a drilled rotor in street use...but if you are going to LeMans, no drilled rotors allowed!
Old Mar 5, 2013 | 08:42 PM
tripleblack05
Thank you,
Old Mar 6, 2013 | 09:43 AM
johnnybravothepimp's Avatar
johnnybravothepimp
I developed cracks in my rear rotors with street use only... They were some aftermarket brand the previous owner put on the car.
Base car, not GS or z51.
Old Mar 6, 2013 | 10:03 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
What HAWK compound are you using? If your going to spend the money for Dba I would look into a pad that is alot more "rotor friendly,"
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Mar 6, 2013 | 10:44 AM
EyeMaster's Avatar
EyeMaster
Small cracks are not fracture cracks. Don't worry about those.
To Brake Rotor Question?
