Those with Eagle Eye tails, please jump in.
So what are the options, WITHOUT having to pierce stock wiring with resistors? Can a pair of CANbus LED bulbs work without hyperflashing? As a comment, I just installed LED boards (Weiser) at the rear of my BMW K1300S bike (resistors built-in), and regular CANbus LED bulbs in the front, and they work perfectly (no hyperflashing). Meaning the rear board resistors provide enough resistance for the entire circuit. Is that the case with the Eagle Eyes? Has anybody tried that? Hope so
. Finally, I found a solution, but I don't like it. And don't like the price either. It's a new bulb from V-leds, but leaves the stock socket dangling, plus the inline resistor as well. AND it might not fit in that limited space. Had a hard time removing the stock socket, and that thing looks a lot deeper.
Anyway, unless somebody has a new alternative, it's either using one of those 26-LED 3157 CANbus bulbs from superbrightLEDs ($19.99 each) or just stay stock. I bought a pair of 'chrome' incandescent amber bulbs, and they failed within 100 miles. Thanks gang.
. Thanks anyway.
. Depends how quick it is. Too quick looks like crap IMO, plus it makes it obvious something's wrong with you car
. If it's just quick, I could warm up to it too. Like somebody said, we don't want resistors if DRLs are going to be on all the time, due to the insane amount of heat that would generate. I don't generally leave DRLs on, but like to have the option when I deem it necessary. As far as the switchbacks, I'd only get those if they were white all the time (headlights on or off), except with turn signals. DRLs look like crap in orange IMO, and the switchback orange is even uglier, for some reason
. Much rather just have an amber LED bulb.I might try CANbus LEDs if nobody has done it. Will wait a few days for answers, before pulling the trigger. But regular LEDs do trigger hyperflashing; I know that due to a few forum members mentioning that, meaning the EE tails don't have excess resistance. Or not that much. Hopefully the 2 little resistors on each CANbus LED bulb is enough to prevent it. Only one way to find out. Vendors advice against it, so might be screwed if I want to return them. Thank you for all your comments folks
