Nitro tires
Old Mar 12, 2013 | 05:38 AM
batpig's Avatar
batpig
Default Nitro tires
why can`t nitrogen be used to fill tires on vettes? I have an012Cruze with nitrogen filled tires ,not supposed to leak, why don`t vette tires use this? Thanks in advance, Batpig.
Old Mar 12, 2013 | 09:07 AM
dndrsn's Avatar
dndrsn
Is there no God?
Old Mar 12, 2013 | 11:45 AM
ChevyDave's Avatar
ChevyDave
i'm willing to listen to why you think we CAN'T. there is a big difference between "dont want to and cant".
you explain how it will benefit you. i'm here listening.............
Old Mar 12, 2013 | 03:21 PM
batpig's Avatar
batpig
Default nitro tire
thanks Dave for responding, you are correct, poor grammar on my behalf. I should have asked what the pros and cons were of using nitrogen.My bad!
Old Mar 12, 2013 | 04:01 PM
ChevyDave's Avatar
ChevyDave
no problem. well, i did a search (at top of page) for nitrogen and for 'in titles only' for C6.
seems the general answer was..
isnt worth the trouble (summary version of their answers) but do it if ya want
Old Mar 12, 2013 | 04:26 PM
Ferocious C6's Avatar
Ferocious C6
Your ignorance tickles me inside.
Air is 78% nitrogen. That means over 3/4 of the molecules in your tire are nitrogen. So yes, your tires do use nitrogen.
Why not use hydrogen-filled tires?
Old Mar 12, 2013 | 05:25 PM
batpig's Avatar
batpig
Default nitro tires
F6 glad I could help!
Old Mar 12, 2013 | 05:48 PM
weez58's Avatar
weez58
the purpose of using nitrogen is to get away from tire pressure increasing as the tire gets hot. The water vapor in air contributes to the heat expansion. That being said, you need to replace all the air with nitrogen, as in pumping a vacuum on the tire and backfilling with nitrogen (usually 3 times). As stated earlier, not worth the hassle.
To Nitro tires
