Need help with fuel level sending unit
Old Mar 13, 2013 | 08:42 PM
marine&hisvette's Avatar
marine&hisvette
Default Need help with fuel level sending unit
I dropped the tank a few times, I dont have my fuel level sending unit hooked up because I get frustrated with looking stuff up.. I'm tired of not knowing my fuel level so will yal please help, I'm using the aeromotive eliminator which requires the controller, that's fine an dandy but it don't tell you where to hook up the sending unit. I'm askin which is + an - on the stock OEM fuel pump harness so I can hard wire it. Thanks!
Old Mar 13, 2013 | 10:40 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Good luck using that fuel pump setup. If I knew what you are looking for, I have mine out now and could look at it.
Old Mar 14, 2013 | 12:09 AM
marine&hisvette
The aeromotive eliminator has 4 terminals.. Obvisly the fuel pump has a pos n neg.. The fuel sending unit terminals are both green.. Where to hook those fuel sending unit lines up? Like to hard wire it to the fuel harness it self
Old Mar 14, 2013 | 10:33 AM
madmax4499's Avatar
madmax4499
I have my tank out now, are you asking which of the green wires is + or-? I dont think they have polarity, it is just a resistance from the sender.
Old Mar 14, 2013 | 12:24 PM
marine&hisvette
In this picture you see where to hook up the wires to run to the harness
In this picture u see the harness it self.. Now which wires should I splice for the fuel sending unit?
Old Mar 14, 2013 | 12:41 PM
madmax4499's Avatar
madmax4499
The two middle wires go to the fuel sender.
Old Mar 14, 2013 | 01:06 PM
marine&hisvette
Doesn't matter which or? And thanks!!
Old Jan 26, 2014 | 09:18 PM
cribbage's Avatar
cribbage
Cruising
Just a resistor, no polarity. Plug it can't go wrong.
To Need help with fuel level sending unit
