Is adding METH still considered N/A ?
Old Mar 15, 2013 | 01:16 AM
cell6ida's Avatar
cell6ida
Default Is adding METH still considered N/A ?
I have a heads/cam/bolt-on build that I just added meth to, so that I can run more timing. I have no nitrous, supercharger, or turbo charger.
Is my build still considered Naturally Aspirated?
Thanks.
Here's the 1/4 mile thread I promised
http://forums.corvetteforum.com/c6-t...-1-4-mile.html
Old Mar 15, 2013 | 08:05 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I'd view it the same as running and tuning on higher octane, so I'd consider it N/A.
Old Mar 15, 2013 | 08:51 AM
speedraider's Avatar
speedraider
Talk to Matt @ FSP in bradenton. He installed mine.
Old Mar 15, 2013 | 09:12 AM
Devilish34's Avatar
Devilish34
Originally Posted by cell6ida
i have a heads/cam/bolt-on build that i just added meth to, so that i can run more timing. I have no nitrous, supercharger, or turbo charger.
Is my build still considered naturally aspirated?
Thanks.
na........
Old Mar 15, 2013 | 11:39 AM
Matt @ FSP's Avatar
Matt @ FSP
St. Jude Donor '13
Would still consider the build N/A... Just spoke to a gentleman last night about adding Meth to his N/A heads/cam package. With higher compression we can take advantage of still running the 93 octane, we can run a few more degrees of timing also. However, this depends on your combination a near stock compression ratio with a good set of heads, there really is no need for the additional methanol spray.
Any questions let me know!
Old Mar 15, 2013 | 01:49 PM
cell6ida's Avatar
cell6ida
Good
Now I can post my 1/4 mile times (in a different thread comming soon) and say that it's a N/A build!!!
Old Mar 15, 2013 | 02:09 PM
LEAVINU's Avatar
LEAVINU
Old Mar 15, 2013 | 07:27 PM
TripleAstyle123's Avatar
TripleAstyle123
Originally Posted by LEAVINU
Old Mar 15, 2013 | 09:57 PM
robz's Avatar
robz
I vote that it's n/a.
Old Mar 16, 2013 | 12:54 AM
LS1LT1's Avatar
LS1LT1
Godd
Yes, just be sure to note/list that you were using the meth injection of course because regardless of whether some view it as NA or a 'power adder', it is still what most will agree a 'performance enhancing mod' usually.
Old Mar 16, 2013 | 01:30 AM
HOXXOH's Avatar
HOXXOH
IMHO a "power adder" is something that adds a significant amount of oxygen to the fuel, even though the methods may vary.
Methanol injection is merely a fuel additive that's introduced at a different point than the gasoline.
Old Mar 16, 2013 | 02:22 AM
LS1LT1's Avatar
LS1LT1
I agree, some might not but I do.
I think the problem some might have with it is that it could open the door to other potential debates on what is classified as NA or not. Such as using a remotely mounted nitrous bottle (or C02 cartridges?) to cool down a radiator, air box or even the outside of an intake manifold between passes or something.
Again, that too should still be considered 'NA legal' as well in my opinion but what if some of it makes it's way into the intake tract? Should unmetered/uncontrolled cooling agents entering your combustion chamber be permitted under NA rules?
Not the same as an alky container and pump of course but just something to think about.
Old Mar 16, 2013 | 11:00 AM
robz's Avatar
robz
I would consider it in the same category as using different fuels that can have more octance or be oxygenated.
Old Mar 16, 2013 | 12:25 PM
5280Racer's Avatar
5280Racer
I haven't seen many people running it on a corvette in my area.. guys who use it could ya chime in with thoughts and experiences..
Old Mar 16, 2013 | 05:09 PM
jon6.0's Avatar
jon6.0
http://forums.corvetteforum.com/c6-t...-n-a-cars.html
http://forums.corvetteforum.com/c6-t...lications.html
Old Mar 17, 2013 | 08:26 AM
Gering's Avatar
Gering
Tolero Apto Victum
Thanks for the thread links!
To Is adding METH still considered N/A ?
