Headlight Lens Replacement
Old Mar 26, 2013 | 10:33 PM
simman22's Avatar
simman22
Default Headlight Lens Replacement
Before I decided to do my own headlight lens I read a bunch of write ups saying you had to remove the bumper, fenders, and a combination of loosening the screws. So here is what I did and it took me about 15 mins to get the light out and about an hour and a half to replace the lens.
The first thing I did is remove the 7 screws holding the fender on (under the hood). Then I removed the 4 screws holding the front bumper top in.
The next thing was to remove the 6 upper push pins from the inner fender (behind the headlight, in front of the tire.
Last was removing the 3 nuts from the bottom of the headlight and the wire plug. with some light moving pieces around the headlight came right out.
I followed a CF member (Old Yellow) instructions on how to remove the lens and it was spot on:
Be sure that you have removed the three nuts with rubber washers from the bottom of the forward end of the light. If they are not removed you will break something. I'm not sure what will break first, but it doesn't matter because you can't get a replacement part without buying an entire headlight assembly. Except for the clear lens. Those can be had form a couple sources on the forum.
I preheated the oven temp to 235. My wife's electric kitchen oven. Once it was at that temperature I turned the oven off. I placed the headlight light on an aluminum cookie sheet and put it in the oven with the rack near the bottom. closed the door, and let it in there for about 15 min. Took it out of the oven & placed it on a cool cookie sheet to start prying it open. Start at the top of the light at the sharp curve. I just used a medium size common screw driver and a steel body panel clip tool.
The first heat cycle wont give you much progress, but you will see the adhesive start to stretch. Reheat the oven to 235 and go for another 15 minutes. repeat the procedure of prying until you get an opening at the top of the headlight. it will be under a lot of pressure but try to squeeze a flat strip of metal into the opening to hold it open while you put it back in the oven. Same heat cycle again. this time the clear lens will start to separate from the black housing a little easier. Not a lot easier, but a little easier.
Now continue prying it open about 1/2 way down one side using your tools. Place that flat strip of steel in the opening as far down as you can get it. Now start on the other side and work the same distance. All the time using a hair dryer, on high, to keep the clear lens hot. Still using the hair dryer go back to the other side and work down a little further. keep going side to side to open it evenly. Try to keep most of the old adhesive on the black housing. It's easier to get it off of there than it is from the clear lens.
I used a 1500 watt hair dryer to extend the working time. Hair dryer heat on the clear lens near the edge worked best. It seems the adhesive will separate from the clear plastic easier than the black.
If you weren't born with four hands, definitely get a helper to hold the light with a towel and work the hair dryer while you pry. I had the assistance of my wife of forty years, but don't ask a girlfriend. This job could ruin a relationship. She, or he will curse you when you slip and stab their hands with the screwdriver, and you will scream at them for burning your hands with the hair dryer, but remain vigilant to the task at hand. You can always get a new helper for free, (Not a wife. They are very expensive to replace,) but these lights are expensive.
Your helper will now avoid you, and not speak to you for several days, but that's a good thing. You can use that free time to prep and paint the lights. No assistance is needed for reassembly so it is not important how long the helper remains angry with you.
As I said he deserves the credit for that fully!
Old Mar 26, 2013 | 10:56 PM
ChevyDave's Avatar
ChevyDave
nice... saved your thread!!
Old Mar 27, 2013 | 12:08 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
readers may want to know where you bought the replacement lens.
Old Mar 27, 2013 | 09:19 AM
simman22's Avatar
simman22
I actually tried to use a CF vender because he had the best price and nothing bad about him but wasnt able to get ahold of him. I definately paid a little more than I could have haha I'll have some patience next time for sure.
Old Mar 29, 2013 | 02:13 PM
C6JOHN's Avatar
C6JOHN
3rd Gear
A few questions. Where did you buy the lens? And, when reassembling the the lens, how did you fasten the parts together, existing glue, new glue? Were you confident that it was water tight when you were finished? Thanks for the thread, you've given me the confidence to give it a try. John
Old Mar 29, 2013 | 04:31 PM
simman22's Avatar
simman22
I got my lens from corvettemods. When I put it back together I used clear RTV adhesive. When you take it apart make sure to get all of the old glue out and just fill the "gutter" around the frame where the lens sits into and when it pushes it out smooth it out around it so you know its sealing correctly. Some people have said you HAVE to use specific glue but I used this stuff on a set of BMW lens over a year ago and they are still sealed. And as far as the confidence, Im not a person to say "anyone can do it" but if you have some mechanic skills and can remember your own steps it is completely doable and will save you some money for sure.
Old Apr 20, 2016 | 05:21 PM
vettl83's Avatar
vettl83
Default Lens removal
I just bought mine from gmparts.com. They came complete with the rubber gaskets, so no need for silicone. They need your Vin. number to get the color right and the three plug sizes. 1.) marker light 2.) fog light and 3.) headlight. My 2008 Z06 took the small plugs. When you get the front fascia off there are (3) 10mm nuts that attach the headlight to the headlight bucket on each side. You must remove the 10mm nuts, then you must remove the first (4) 7mm nuts from the right and left fender, this enables you to gain clearance to remove the headlight while lifting up the fender about an inch or so. When your ready to align the headlights there will be (2) one inch holes one on each side, inside under the hood up front, if you look in there with a flash light you will see a hex screw. Turning this screw will adjust the headlight up or down, last thing to do after the install is complete. If you need any more help don't hesitate to contact me.
Old Apr 20, 2016 | 05:46 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
What a great Thread Simman22! Thanks for taking your time to take pictures and do this write up.
And your write up is very well written! LOL I'll make my son help me if I ever need to do this rather than my wife. lol
Old Apr 20, 2016 | 06:12 PM
R_W's Avatar
R_W
Good write up!
EDIT: Just realized we were necro-bumping this thread. lol
Old Apr 21, 2016 | 04:37 PM
schizcat's Avatar
schizcat
Nice write up
Wanna take an hour drive south and knock mine out?
Old Dec 18, 2016 | 07:25 AM
dreskiluv's Avatar
dreskiluv
Vette family thanks for taking the time to help out a newbie to the Vette world and this forum.
Old Apr 23, 2018 | 02:44 PM
Clking550's Avatar
Clking550
1st Gear
Default Repairshop in Middle GA?
I am looking for someone in the middle Georgia area who will install a new lens cover on my 2007 Corvette. In am not mechanically inclined. Just saying.
Old Apr 23, 2018 | 02:54 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Check out my instructions on my website www.c6c7vette.com
There have been many many who didn't know a screw driver from a wrench that completed the job with great results and saving them money.
You can also try Buy-a-Vette in Atlanta as they buy my lens. They may be willing to do the replacement for you.
You can also send me your lights for my lens replacement service. All info on my site. turn around time is usually a few days, not weeks.
Old May 2, 2018 | 04:13 PM
RobJoy's Avatar
RobJoy
Default help...
That could cost you a lot of beer...
Old Jul 10, 2018 | 09:13 PM
LightningBrett's Avatar
LightningBrett
Thanks to all who have given input to this task. I heated mine to 250 for 20 min. 2 times for lens. 6 times for glue removal. You don't need a helper. Just a PITA. Going to start on drivers side in the am. Worth every bit of the $500 labor if you don't have time, tools, and beer.
Old Jul 27, 2025 | 02:43 PM
JpdelPozo's Avatar
JpdelPozo
8th Gear
Great instructions! Even better read!
To Headlight Lens Replacement
