modified C6 stalling
Old Mar 31, 2013 | 08:47 AM
David's C6's Avatar
David's C6
Cruising
Default modified C6 stalling
My C6 MT has headers, cam (230-236 @600 lift with 114 separation), and en E-force. It makes 612 at the tires but often stalls after being started following a short stop like at a gas station. it does not stall if the motor is cold, just when warm. This is more common on hot days and rarely occurrs during the winter. The tuner minimized the problem by increasing the idle to about 900 rpm but it still happens, the hotter the day the more frequent the stalling. It rarely happens in traffic, usually just after starting. Any ideas or suggestions?
Old Mar 31, 2013 | 08:53 AM
1MEANGS's Avatar
1MEANGS
Sounds like a tuning issue! My old Saleen Mustang had the same issue & my mods were a fully built motor\ blower... When I got it back had the same problem lend up having a falling out with the shop and switching to another and the car drove like stock with the new tune
Old Mar 31, 2013 | 09:16 AM
Dynosteve's Avatar
0Dynosteve
Former Vendor
sir its in the tuning tables you will need to have the fuel and airflow tables adjusted at idle
To modified C6 stalling
