What is the correct c6 z51 front spring
From the C5 Tech Forum:
I'm selling my old T1 springs, and in raised lettering on the springs are the numbers: 22188479 and 22188480
The GM part numbers for the T1 springs are 12480063 and 12480064
I found this information from the forums:
Part Number Casting Num Code Rate Years Suspension Useage
22178728 440# 97-02 FE1 w/o F45 All bodies with soft ride susp FE1,(EXC Chasis Realtime Damping F45)
22178729 22171750 AY 525# 98-00 FE3/Z51, FE4/Z06 All bodies with sport suspension Z51/FE3 and Z06 suspension FE4
22178748 457# 99-02 FE1 with F45 Y07-67 Soft ride suspension FE1, Chasis realtime damping F45
12480063 22188479A 582# 97-02 T1 New New style T1 front spring
22188479 582# 97-02 T1 Old Old style T1 front spring
Rear Springs
22179019 577# 98-03 FE1 with MM6 All bodies with 6 speed MM6 and Soft ride suspension FE1
22179020 22171757 RJF 634# 98-00 FE3/Z51 with MM6 All bodies with 6 speed MM6 and Sport suspension Z51/FE3
22146323 588# 98-03 FE1 with M30 All bodies with 4-spd auto trans M30 and Soft ride suspension FE1
22146646 645# 98-03 FE3/F51 with M30 All bodies with 4-spd auto trans M30 and Sport suspension Z51/FE3
22188038 22188078 RJH 714# 01-03 FE4/Z06 with M12 Z06 Hardtop with 6 speed M12 and FE4 Suspension
12480064 22188480 794# 97-02 T1 T1 Rear Spring"
What I/the buyer want to know is why GM has different part numbers/ casting numbers. And under scrutiny by an SCCA official, will they know that these are legal T1 springs?
Thanks for the help
And post 8 in here says it isn't as heavy as the C6 spring.
http://www.digitalcorvettes.com/foru...ad.php?t=44205
