C6/A6 Slight Fishtail Issue
Old Apr 7, 2013 | 03:28 PM
04goatman's Avatar
04goatman
Default C6/A6 Slight Fishtail Issue
Hi Forum, I just got a new 08 C6/A6 vette, I really like the car. My issue is with the straight line grip from the car. I was accelerating on the highway to pass someone and I noticed the back end give me a fishtail, mind you I was going about 65-70, I immediately got out of it. I tried it again later on the trip and the vehicle displayed the same characteristics.
Details:
Car is all stock
50 degrees temp night time the tires were warm from driving many miles.
Tires are Firestone Firehawk Wide Oval RFT
Is my issue most likely related to the run flat tires and temperature?
Would a pair of nitto NTO5’s fix this?
What suspension mods should I consider?
Old Apr 7, 2013 | 04:58 PM
Le Mans Z06's Avatar
Le Mans Z06
What are your mods? It seems Corvettes like to fishtail more than some cars. A stickier tire should help with it but depending on your mods it may not fix it but only help bandaid it.
Are you keeping traction control on or taking it off? I suggest taking it off when playing around.
Old Apr 7, 2013 | 05:45 PM
truckplay's Avatar
truckplay
those are still Summer tires. when the ground and tires are cold they will not grip well. Upgrading sway bars and rolling onto the throttle may help also. I remember the first week I had mine, on the lousy GY's, the car came around on me when I stabbed the throttle too hard too fast.
Old Apr 7, 2013 | 05:46 PM
04goatman's Avatar
04goatman
Car is all stock, I had the TC on because we were on the highway. I have heard about the negative performance of the run flats vs the non run flats.
Should I turn the TC off when I am playing with it, even if I am above 50MPH, something tells me that turning this off is a recipe for a fail, however I have been wrong before.
Old Apr 7, 2013 | 05:53 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
about the only thing you can do is get some scales and corner balance the car. at least when it does break loose it stays straight
Old Apr 7, 2013 | 06:54 PM
haljensen's Avatar
haljensen
Details:
Car is all stock
Leave the traction control on. The only thing that needs to change is your driving style. Floor the car at that speed and it downshifts far enough that you are at peak HP at high RPM on cold pavement. Flooring the gas pedal tells the Computer that you want maximum power, that's what you got. Ease into the throttle and you won't have a problem.
Old Apr 7, 2013 | 07:57 PM
AIR_RAM's Avatar
AIR_RAM
LOL... It fishtails because it overpowers the tires when you go WOT. If your steering wheel is turned even the slightest you should be ready for a slight kick in the opposite direction...
Best advice is it get used to it so your reactions to it become natural and instant... And most of all enjoy it.
FYI... when coming from a HIGH SPEED to a hard braking stop you will learn the tail end will do the EXACT same thing... just let of brake, gain control and reapply brake... its real simple but will scare the hell out of you the first time if you have never experienced it before.
SPEED SAFE,NICK
Old Apr 7, 2013 | 11:29 PM
lionelhutz's Avatar
lionelhutz
Was it spinning? Most likely but just had to ask. I'd think you'd see a message about the TC or AH being active if you were spinning.
I'd just running a LS1 with some bolt-ons and older PS2's and when it's cooler I can spin it through the first 3 gears. You've got way more power so I'd think you're easily lighting it up. Better rubber will help but most high performance summer tires just don't like cold temps.
When I picked up my C5 I could barely keep it in one lane running WOT at any speed. It was the alignment all messed up, probably because it was 10 years old and had never been aligned. So, I'd recommend an alignment just to know it's good. And get a good one. Every number side to side should be exactly the same except the caster on the right front can be a little more than the left front to compensate for road crown. Say about 0.5* more is the most you'd want. I've seen many posts with crap alignments that were "within spec". The problem is that using "within spec" gives a bigger range then the setting itself.
I would not turn the TC/AH off. You just can't predict day to day changes in street conditions. We don't need to read your next thread about how you totaled your car.
Old Apr 9, 2013 | 04:16 AM
C6LS3's Avatar
C6LS3
were your tires cold? that could cause poor grip. try it when it gets hotter and see if it does it.
Old Apr 9, 2013 | 04:38 PM
04goatman's Avatar
04goatman
Well the tires should have been warm from traveling, however it was night and the ambient temp was about 50 degrees.
Old Apr 9, 2013 | 11:57 PM
Rathmullan's Avatar
Rathmullan
Details:
Car is all stock
From what I've read, this problem seems more common with auto C6s and when the transmission is in automatic mode (not manual paddle shift mode). As someone pointed out, when you jump on the throttle hard the transmission will automatically downshift the car to a gear that may sometimes surprise the driver in terms of the resultant rpms and torque delivered to the rear tires. And yes the tires will break free particulary in colder weather or if there are remnants of cinder, sand or salt, used for "traction" in winter driving conditions, on the road. My own personal experience has been that the tires can break loose even a few seconds into an acceleration as these LS engines can sustain high torque output levels for sometime and even build torque! So I wouldn't blame your tires just yet. Personally, I plan to use the paddles most of the time as other forum members have mentioned. Otherwise, in cooler weather and in auto mode, rolling into the throttle and avoiding that abrubt downshift is the safer option.
Old Apr 10, 2013 | 12:35 AM
lionelhutz's Avatar
lionelhutz
Distance driven doesn't mean much when the road surface is cold. The tires will never get as hot as they would on a hotter day or when the sun is out.
Old Apr 10, 2013 | 02:09 AM
JCtx's Avatar
JCtx
That's negative man. When only one rear tire loses traction while accelerating hard, car goes sideways in a hurry, even with all the nannies on. Since both rear tires are spinning (but only one has traction), AH doesn't respond quick enough. Like somebody said, if you don't have quick reflexes, you'd do a number like a video posted on Youtube of a C5 and a C6. It has happened twice already on my relatively new GS, which is in perfect mechanical condition, tires perfectly inflated to 30 psi, and less than 3K miles on it.
Just like it was mentioned, the problem is TRACTION. Both times it was in the 50s as well. My car is a manual, and didn't go WOT myself... but still too much torque for the available traction. One of those times my daughter just about crapped on her pants , and I was crossing a yellow light, so couldn't lift, and had to fishtail thru the intersection. I must have caught sand, or something slippery, losing traction on just one side. You have to be really careful with these cars below 60º, even with all nannies on; they don't help at all in those quick slides. And on the GS, there's no other tire choice but summer. So there you have it folks: NEVER overestimate summer tires.
Old Apr 10, 2013 | 07:18 AM
Ferocious C6's Avatar
Ferocious C6
Oh, the "problems" of this forum.
I dumped the clutch at 4,000 and my tires still spun with traction control on. What's wrong?
Old Apr 10, 2013 | 09:26 AM
kmthor00's Avatar
kmthor00
Did you have your interior lights on?
Old Apr 10, 2013 | 10:39 AM
Rathmullan's Avatar
Rathmullan
I know. It's just criminal how much horsepower and torque GM has built into these cars
Old Apr 10, 2013 | 01:53 PM
MBB's Avatar
MBB
I drive like a nanny until my tires heat up and go up about 2-3psi. My 1st gear is useless...as is early 2nd gear.
To C6/A6 Slight Fishtail Issue
