Bilstein shocks worth the upgrade?
Old Apr 7, 2013 | 05:16 PM
steventx's Avatar
steventx
Default Bilstein shocks worth the upgrade?
2005 Z51 coupe is what I have. 73000 miles...Currently on stock everything. I am a daily driver of my vette. 25 miles each way to work on a fun curvy country road, then about 5 miles on I35 straightaway. Anyone have advice on the best shock upgrade for my year and model? Half of my drive is on "gravelly" asphalt which is kinda annoyingly loud, other have is great smooth asphalt. Im wanting to upgrade the shocks but being sure to upgrade the smoothness too and hopefully quieting the loud surfaces...DONT want to loose performance at all though on fun curves. Is Bilstein sport shocks the way to go? Saw some on Summitt that looked like a good deal. Just want to be sure and get the best...So Any sound advice would be greatly appreciated. Thanks!
Old Apr 7, 2013 | 05:17 PM
timd38's Avatar
timd38
I had on my car before the coilovers and I would buy them again.
Old Apr 7, 2013 | 05:40 PM
SSTEVEGS's Avatar
SSTEVEGS
I've got them on my car but haven't really had a good chance (due to cold weather and salty roads) to see how they handle. Mine are the DRM Bilsteins available to forum members in a recent group purchase. So far, I like them a lot and can't wait to hit the back mountain roads this spring! One thing you'll notice for sure is that they're quite a bit stiffer than the factory Z51 shocks but depending on what you're looking for, it's not bad. I switched to non-runflats and saw an immediate improvement due to their sidewall flexibility.
Old Apr 7, 2013 | 06:20 PM
Justasheet's Avatar
Justasheet
Love the HD's. Here's my post, some time back.
Jeff
http://forums.corvetteforum.com/c6-t...-on-a-z51.html
Old Apr 7, 2013 | 06:28 PM
boraxman's Avatar
boraxman
DRM's here...Would do it again
Old Apr 7, 2013 | 06:39 PM
cclive's Avatar
cclive
Jeff
Love mine too. $300 for the set
Old Apr 7, 2013 | 09:34 PM
Mike's LS3's Avatar
Mike's LS3
Yes, I installed the sports at 46k miles on my 08 Z51 coupe and love them. Perfect shock for the Z51 package, should of been oem. At least GM got it right for the C7, Bilstein's will be oem shocks!
Old Apr 7, 2013 | 11:04 PM
cclive's Avatar
cclive
GM had it right on my '85 Blazer... Bilsteins were part of the factory off road package...
Old Apr 9, 2013 | 04:22 AM
C6LS3's Avatar
C6LS3
DRM Bilstein custom shocks are great!
Old Apr 9, 2013 | 08:01 PM
CrvtBB's Avatar
CrvtBB
Veteran: Coast Guard
I recommend considering Koni FSD's. Excellent shock, but usually a bit pricier than the Bilstein's unless you can find a great deal.
Old Apr 9, 2013 | 08:50 PM
360jeepboy's Avatar
360jeepboy
So the Sport is the best ones for the Z51?
Old Apr 10, 2013 | 09:48 AM
LFZ's Avatar
LFZ
No...the DRMs are.
Old Apr 23, 2013 | 11:01 AM
CloudLS9's Avatar
CloudLS9
Here are my thoughts on the DRM Bilstein. The executive summary is that they improve handling but ride quality over rough surfaces improves a great deal contrary to expectation.
http://forums.corvetteforum.com/c6-c...agnaflows.html
Also, there is a difference between the Bilsteins you'd get at Summit and the DRM Bilsteins. The Doug Rippie Motorsports Bilsteins are specifically valved (tuned) for the C6. I'm sure the general Bilstein's are still an improvement over stock, but it stands to reason they can't be ideally suited for all fitment applications. I went with DRM (and his $25 upgrade bushings) as so many others have raved about this set-up and now I know why :-).
Old Apr 23, 2013 | 11:50 AM
Bill Dearborn's Avatar
Bill Dearborn
I installed them on my C6Z along with the upgraded bushings. Much better ride and handling. Drove the car from upstate NY to Key West and back along with a stop at Sebring to do some instructing. They were great compared to the stock very stiff shocks.
Bill
Old Apr 23, 2013 | 03:03 PM
vette6500's Avatar
vette6500
Put on DRM Bilsteins + poly bushings several weeks ago (had Bilstein Sports before).
After couple drives, the DRM Bilsteins + poly bushings have been shining! My '05 has become such a pleasure to drive, it feels so planted and feels more accurate than ever!
Will get to test them out at autocross this Saturday before deciding if I need an alignment or not.
But on the freeway, the feel and accuracy has never been better.
I highly recommend DRM + poly bushings over the regular Bilstein Sports.
Old Apr 23, 2013 | 03:26 PM
victorf's Avatar
victorf
Bilstein Sports for my '05 Z51, $297 w/Free Shipping deal from MidAmerica.
Tried the DRM poly shock mounts(installed less than 500 miles, already suffered permanent deformation when disassembled), then removed/replaced with Pfadt Spherical delrin upper mounts - difference in free articulation from the DRM poly bushing is day and night - way more costly - but the handling difference is something you would appreciate only if you have done it.
Doing it in stages is the only way to realize if there is any change.
By installing Hotchkis sways F/R after the above, it will be like icing on cake for the basic Z51 improvement on the practical level without going too wild.
Again, in stages to fully appreciate the improvements.
Old Apr 23, 2013 | 07:25 PM
LFZ's Avatar
LFZ
Actually the DRM Bilsteins were specifically valved for the C6 Z06 to tame the twitchy rear, oversteer, and give an overall planted feel for the car. An area that has been lackluster on the Z06 since 2006. GM even revalved the standard OE rear shocks in mid 2007 model year, and IMO still couldn't get it right. This is where DRM came in to save the day.
To Bilstein shocks worth the upgrade?
Old Apr 23, 2013 | 11:46 PM
JerriVette's Avatar
JerriVette
I have the bilstein sports from tire rack on my 60k mile 2008 c6 z51.
A hundred or so less then the drm s...I went with the. Sports as they are a replacement for the z51 shock.
Nice replacement' less cost and a nice balance of ride and handling.
When I first did this about 10k miles ago I could say I noticed an improvement and it was a good mod.
Now it just feels normal ...I read the reviews of the DRM and they sound good. I almost did it but decided to save the hundred or two hundred...since the drm were designed for the zO6.
HtH.....tHe sports are better than stock but now 10k later it's hard to remember the old setup
Old Apr 24, 2013 | 09:07 PM
Thunder8's Avatar
Thunder8
When I first did this about 0k miles ago I could say I noticed an improvement and it was a good mod.
Now it just feels normal ...I read the reviews of the DRM and they sound good. I almost did it but decided to save the hundred or two hundred...since t)3 drm were designed for the zO6.
HtH.....tHe sports are better than stock but now 0k later it's hard to remember the old setup
I did the same and actually really like the Sports. I don't have the z51 suspension, but I also did the poly bushings and added the z51 sways. The difference to me is dramatic. The car feels like it should and I really like the ride too!
Old Apr 24, 2013 | 09:54 PM
MSTROBES's Avatar
MSTROBES
YES
