Installing PFADT's Tri-Y
Old Apr 9, 2013 | 08:57 PM
FRDnemesis's Avatar
FRDnemesis
Default Installing PFADT's Tri-Y
My heads are on the way back and I should have them by early next week. One of the new goodies I have to install are my new header/X-pipe system on my Z06.
Are there any tips or tricks that make these headers any different to install than the LG's I took off the car?
Just curious about fitment.
Old Apr 9, 2013 | 10:24 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
hammer and grinder should help.
Old Apr 10, 2013 | 01:56 PM
Bedouin's Avatar
Bedouin
I used a couple small pieces of 2x4 between the x-pipe & the tunnel, towards the back where they spread out to the cat back system, & this really helped center the system in the tunnel before final torque on the header bolts & v-band clamps.
Old Apr 10, 2013 | 02:07 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
use studs, they are better to use when working with aluminum threads and it makes it easier to hang the headers and gaskets
Old Apr 10, 2013 | 02:52 PM
wstaab's Avatar
wstaab
Leave everything slightly loose, header bolts, v-band clamps, and muffler clamps after you install all the parts. Then line everything up, center the x-pipe in the tunnel, line up the muffler tips, then tighten the header bolts, v-band clamps next, muffler clamps last.
Good luck.
Old Apr 11, 2013 | 06:22 PM
Pfadt Racing's Avatar
Pfadt Racing
awesome pics wstaab!
Good suggestions guys. Thanks for the input
To Installing PFADT's Tri-Y
