How to replace shocks
Old Apr 21, 2013 | 10:45 PM
hawkandersonjr's Avatar
hawkandersonjr
From: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
Default How to replace shocks
Looking for some direction on how to install a set of OEM shocks on my 2005 Vette, FE1 suspension (non-Z51). I ordered them from Gene. Is there a special tool needed except from your basic tools. I have no car rack so I will be using jacks. I did a search but found no installation information.
Old Apr 22, 2013 | 12:16 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
You technically do not need any special tools, but the Lisle Universal shock tool will save you lots of time on the fronts at least.
On our cars shock changes are pretty easy. All you have to do is get the car in the air, remove the wheels and then place your jack under the ball joint on the corner you want to work with and then unbolt the shock (bottom first). Use the jack to get the shock in a neutral position so that the bolt just slides right out then remove the top bolts.
What I did next was just grab the bottom half of the shock and push up with the help of my legs and the shock compressed enough for it to clear all of suspension without taking anything else apart.
There are a few good DIY's here on the forum with some pictures as well but I had never done shocks before and I was done in about an hour and a half.
Old Apr 22, 2013 | 08:16 AM
MSTROBES's Avatar
MSTROBES
I change my shocks last week. top bolt first then the bottom bolts. very easy.
Old Apr 22, 2013 | 09:40 AM
boraxman's Avatar
boraxman
You will want some long zip ties, still may to use a couple together to compress and hold the shock compressed to clear getting them in and out. This helped me big time.
Old Apr 22, 2013 | 02:15 PM
Flame Red's Avatar
Flame Red
I did mine a few weeks ago. The rears are no problem at all. The fronts are bit harder.
Remove the tire on the front and the use a scissors jack or hydraulic jack on the bottom of the A-Arm to jack up the spindle until it begins to live your main jack off your pucks. This will compress the front sock.
Then use some safety wire, which is some single strand wire that you can get at most auto parts stores or Home Repo and wrap it around the top and bottom of the shock and tighten it up by twisting the wire together with a pliers until the wire is taught. Remove the shock bolts. Now lower the spindle jack. The shock should stay compressed and you should have plenty of room to remove it.
When you put the new ones in, compress them and wrap them with wires if they are not already strapped in the compressed position. They should go in really easy compressed. Jack up your spindle again and get the bolts on. Then you can cut the straps or safety wire.
To How to replace shocks
