Tire Pressure Sensors
Apr 22, 2013 | 08:52 PM
If the tires and wheels from a 2013 C6 are installed on a 2006 C6, can the computer be reprogrammed to read them, or do we need to replace the sensors in the tires?
MC
Apr 22, 2013 | 09:18 PM
No.
The sensors changed in 2010 and are not compatible with earlier years.
Apr 22, 2013 | 09:25 PM
Sensor Response
Quote:
Originally Posted by
RicK T
No.
Thank you...the 'techs' at Champion Chevrolet are trying to get the 2013 sensors to work on my car......
Fortunately, the new car department bought a set of four 2013 sensors to install....
Thank you!
Apr 22, 2013 | 09:35 PM
Huh!?!?!?
A Chebie dealership doesn't know what sensors are needed in what model year????
Like Rick says, the TPMS computer was changed for the 2010 model year and it requires a different sensor.
The 2005-2009 uses this sensor:
You can see the GM part# 25758220 molded into the case. The 2006 requires these gray sensors.
Give the parts department that part# above to get the correct sensor.
Bob
Apr 24, 2013 | 07:18 PM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
MCharlie
Thank you!
I hope they didn't order 2013 sensors, They won't work in a 2006. Maybe you mean new sensors for a 2006?
Apr 24, 2013 | 07:26 PM
Mr.Bill
No, they ordered the correct sensors,,and the new sensors read the tire pressure fine now.
Apr 26, 2013 | 02:26 PM
oky doky...the new sensors are in place....What would the general readership here recommend the front and rear tire pressures be set to?
Thanks!
Apr 26, 2013 | 02:39 PM
Apr 26, 2013 | 06:09 PM
