Window Regulator
Old Apr 25, 2013 | 02:22 PM
ZR1Gerhardt's Avatar
ZR1Gerhardt
Default Window Regulator
I have a slight rattle in the driver side door glass. It occurs whether the window is up or down. I am going to pop the driver door panel off this weekend and take a look.
I am guessing the window regulator is loose. So I will lower the window and check where it attaches to the window, etc. Anything else I should look for?
Scott
Old Apr 25, 2013 | 09:21 PM
VET4LES's Avatar
VET4LES
This what they look like. I've had both or them replaced.
Old May 7, 2013 | 12:11 PM
ZR1Gerhardt
Thanks, fixed it.
Only problem is I scratched the paint a little where the damn metal clips hang on the ledge. Obviously no one can see them behind the door panel, so it is not that big of a deal, but nonetheless, not exactly how I would like it. It would seem that the GM engineer who designed the door panel has no experience in installing said door panel.
Scott
To Window Regulator
