Fuel mileage question
I was asking because my car is modified, ProCharger, 60# injectors, hedders, etc., and I was wondering if the fuel mileage was accurate.
Yes, I'm too lazy to do it the old fashion way!
See, ask a question, get a question!
Elmer
I really don't know. The car was initially tuned by sending the ECM off to the ProCharger tuner upon initial installation, then once everything was installed, I drove the car to a local shop where a fairly conservative tune was installed. The car makes 550 rwhp, whereas I've seen cars with the same specifications as mine putting down 600+, so I know there is more in the engine, but honestly, the car is scary fast the way it currently is configured, so I probably will not seek additional power. But, not sure the basics of the tune. Not in my area of expertise.
I was just curious about the mpg accuracy.
So, the tuner reloaded the stock tune and then tweaked the files as needed to make it work. I now get 28-29 on the highway and the miles in the tank are accurate. I really can get the 400 miles left in the tank easy.
So, What do you have? LS1? It should be ok and if the numbers on the instant MPG look reasonable, then the remaining in the tank numbers should be fine too. I'd guess that the ECM calculates via math the mileage as it knows everything going on in the engine as far as air & fuel flow.
Elmer
