HELP..."hot engine, A/C shut down".
Last fall I started getting a message that said "low coolant". I have an LS9 ZR1. My coolant was fine in my engine reservoir and in my intercooler. Fast forward to this Spring and the car has been out for a couple of weeks and suddenly I try and start it and it turns over too many times but starts, thought that was weird, but I carry on. Then at a stop light I hear this noise, sounds like my fans running, (never really hear them too often), I look at my DIC and it says "hot engine, A/C shut down". My temp gauge is reading 0. I get it home and it didn't seem to be overheating at all. I Googled and searched, saw some guys with the same problem, but all I have learned is, none of the vehicles were overheating. Anybody have some clues?
TIA.
Or even if anybody has any clues on the "low coolant" message. These could be related or not.
My dealer will replace anything I ask them to do under warranty, so we started with thermostat after the MOntreal incident, didn't help.
We put some dye into the rad fluid, drove it a couple of hundred kilomoters and then looked at the whole engine bay under black light, no leak.
They have ordered a new temperature sensor for me and will change that when the part comes in. My guess is the the temp sensor. As you saw from another post, the car uses software (cheaper than hardware) to determine coolant level.
If it happenes again, switch the DIC over to coolant temperature. When i did the DIC displayed, 220, then 170 then 210, then 160 and kept changing, which tells me it is bad. And if it goes bad then it would give us the coolant level error.
I will let you know what happens after they change the temp sensor
Thanks again.
Thanks to Josh at HorsePower Addicts in Delaware.
I didn't smell anything or see anything, but I ran the heat on high just in case until I could pull off and get into a parking lot. Hoses weren't hot and coolant was full....so I just called it a fluke. Happened once more a couple weeks later, but never again after that.
I've been battling this for almost 2yrs now but only in the colder months. I've replaced the coolant sensor (driver side at front of head behind the alternator) twice and the problem still comes back so I've crossed that off the list. Fluid has been flushed (block and all) three times and that never solved anything.
What I have learned/realized is that the PCM has a timer for the coolant to reach normal operating temp. What that exact temp is I'm not 100% certain but seems to be 160*F. If I hop in the car in the dead of a cold morning (below freezing or close to it) and dont let the car idle to warm up I'll get this message within a few miles. If I let the car idle in the garage thereby reaching 160*F before pulling out of my driveway all is fine EVERYTIME.
What I'm thinking is that the cooling system (mine has been upgraded) is too efficient and it hinders the warm-up time in cold weather. This can be similar to the situation the C6Z guys have always had with their oil due to the large oil cooler at the front of the radiator.
Letting my car idle in the garage gives it no air across the coolers to "cool" or slow down the warm-up process.
Like I said, I've been dealing with this for almost 2yrs now and just letting the car fully warm-up eliminates "my" issue.
No way to say this is your problem as well but seems we have similar symptoms and given your geographical location it very well could be yours as well.
On our C5, I had an oversize radiator installed and got a Check Engine light, the dealership said it was because the car wasn't warming up properly and it must be because of my big radiator. I told them it must be the thermostat, and change it; if that solved the problem then it's a warranty repair and if not then I owe them for the new thermostat and installation.
New thermostat cured the problem.
Tom
Tom
Literally just had this happen a week ago after the cam install. Replaced the sensor and still nothing. Found out one of the "very tiny" wires that goes into the sensor pulled apart in the loom. Trace the wire. It's small.
