Gear vs mph charts
Old May 1, 2013 | 10:22 AM
Boombastic's Avatar
Boombastic
Default Gear vs mph charts
I will be changing my gears on my 06 auto z51 from 2.56 to 3.42. At present the rpm at 60 mph is about 1400 rpm and at 75 mph it's at 16 to 1700 rpm. Any idea as to what rims may be with the 3.42 gear change?
Old May 1, 2013 | 11:06 AM
ejbarre's Avatar
ejbarre
I did the same thing to mine, 3.42 gears, A6. 70 mph = 2000 rpm. I haven't really paid attention to the other speeds.
Old May 1, 2013 | 11:10 AM
mancobra's Avatar
mancobra
where did u get your gear ?
Old May 1, 2013 | 11:23 AM
Boombastic's Avatar
Boombastic
Dasilva Motorsports in Breslau near Kitchener. Ask for manny at 866 992 3752. I will be putting the gears in next week
Old May 1, 2013 | 11:31 AM
timd38's Avatar
timd38
RPM has gears and if you get a diff side cover that will accept a cooler, they will cut the pinion to drive the pump.
Old May 1, 2013 | 11:43 AM
Boombastic's Avatar
Boombastic
Huh. Did I miss something. How does this relate to my post. Thanks
Old May 1, 2013 | 12:07 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I have spreadsheets that can calculate that but have no idea how to post them. You can figure it out with a little data here...
http://www.wallaceracing.com/calcmph.php
Old May 1, 2013 | 12:18 PM
WayneCar's Avatar
WayneCar
Or use this one if you want to determine speed for multiple gears
at various RPM.
Wayne
http://www.f-body.org/gears/
Old May 1, 2013 | 12:53 PM
jpick's Avatar
jpick
RPM what? Is that suppose to be a vendor?
Old May 1, 2013 | 02:03 PM
njfl's Avatar
njfl
It should be a linear change. To calculate the new rpm with only changing rear gears, multiply the rpm by (in your case) 3.42/2.56. I get your new rpm at 60mph to be 1400x3.42/2.56=1870 and at 75, 1650 goes to 2204.
Old May 1, 2013 | 02:22 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I have this but I don't know if it helps you.
Elmer
Old May 1, 2013 | 08:49 PM
Vette_DD's Avatar
Vette_DD
60 MPH = 1760 RPM
75 MPH = 2200 RPM
http://mysite.verizon.net/foofoo2/c6/A6-3.42.html
Old May 1, 2013 | 10:16 PM
Gering's Avatar
Gering
Tolero Apto Victum
Yes. http://m.rpmtransmissions.com/c6pricing.html
Old May 1, 2013 | 10:48 PM
jpick's Avatar
jpick
Originally Posted by Gering
Thanks buddy!
To Gear vs mph charts
