Help!!
Old May 1, 2013 | 04:57 PM
ColtaBilly's Avatar
ColtaBilly
Default Help!!
I changed clutch in my 05 C6 coupe and now the clutch pedal will not go in. I reconnected the mater cylinder pushrod and no way to engage the clutch. Am I missing something simple??? Please help.
Old May 1, 2013 | 06:30 PM
ColtaBilly's Avatar
ColtaBilly
ttt
Old May 2, 2013 | 07:34 AM
ColtaBilly's Avatar
ColtaBilly
Ok, I figured out that the problem is the hydraulic line running from master to slave is not fully connected. I am having trouble getting it fully engaged. Anyone have a trick to snapping the connection together?
Old May 2, 2013 | 10:14 AM
KillerFRC's Avatar
KillerFRC
I normally pull the inner finder out so I can access from both sides.
Its a pain to line up sometimes and you may need to release the pressure on the master line by pushing the quick connect plunger in.
Old May 5, 2013 | 07:00 AM
ColtaBilly's Avatar
ColtaBilly
Thanks Killer, that is exactly what I had to do. Thanks!
To Help!!
