leaf spring bolts
Old May 8, 2013 | 09:19 AM
doubledsyellow's Avatar
doubledsyellow
Default leaf spring bolts
Was trying to level the vette because had some variations on ride hight. Noticed the rear was very easy to adjust and not worn too bad. The front bushings under the bolts were worn pretty good and a pain to break free. I want to replace either all four and at least the front bolts. Any recommendations ? I don't really want to change the whole leaf springs to get the oem ones. Wouldn't mind a 1/4-1/2 inch drop. Thanks.
Old May 8, 2013 | 10:54 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Spring adjustment bolts are not available as a separate item, unless you find someone who has theirs left over from some changes.
