MAF Problem
Old May 8, 2013 | 03:32 PM
AndreasK's Avatar
AndreasK
Default MAF Problem
Setup: Z06 with headers and Vortex Ram Air inlet. Use Predator Diablo tuning the one called headers, it has been benched previously by former owner so it may be custom tuned as well).
The car runs fine most often but sometimes either at full throttle or very little it missfires for a second and the check engine light lights up.
Get these error codes:
P0101 Mass or Volume Air flow Circuit, range perfomance
P0102 Mass or Volume Air flow Circuit, Low input
Old May 8, 2013 | 06:04 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Could be turbulence from the Vortex Ram Air. I had that same intake on my 06 which pulled H.P. and the fix was a different intake. I now successfully run with a K&N. Try going back to your stock intake and see if your problem goes away. I'm now running with headers, Fast intake manifold, ported T.B. and K&N with no MAF issues.
